automatic shifter getting stuck
Old Jun 29, 2007 | 06:34 PM
civic8888's Avatar
civic8888
Default automatic shifter getting stuck
My automatic is having trouble getting out of park. I don't abuse it at all. It has been progressively getting worse. Any ideas on what could be wrong, and how to fix it? thanks
Old Jun 29, 2007 | 08:06 PM
Fuse's Avatar
Fuse
Check you brake lights when this happens. More than likely it is you brake switch failing and or getting stuck off.
Old Jun 30, 2007 | 12:42 AM
A-series's Avatar
A-series
v-card member alpha
Does the button you push to take it out of park appear to be working normally?
I mean, does it have the same resistance, etc.
Just throwing it out there as another possible cause, though I've never heard of that failing on a honda.
Old Jun 30, 2007 | 05:22 AM
civic8888's Avatar
civic8888
the button seems fine. Thanks for the input though!
Old Jun 30, 2007 | 02:58 PM
civic8888's Avatar
civic8888
The break lights are fine too I checked them earlier. I did some research and found out two things that are likely to go wrong. One is the shifter solenoid, but I don't think that is the problem because I noticed it shifts bad not only out of park but also into park and between reverse and drive sometimes. Another thing is the shifter cable, which seems more likely. Does anyone know where the shifter cable is? I took off the plastic around the shifter, but can't find it.
Old Jul 7, 2007 | 10:38 PM
flappy188's Avatar
flappy188
O.G. SON!
underneath the chasis
Old Jul 11, 2007 | 04:48 PM
p_quinones's Avatar
p_quinones
shifter cable is under the car. i had the same problem a few weeks back i got it changed and its fine now
Old Jul 11, 2007 | 10:55 PM
Kabooki's Avatar
Kabooki
low fluid will cause hard shifting/late shifting when switching to drive.
Old Jul 12, 2007 | 02:14 PM
civic8888's Avatar
civic8888
Default Thanks for all the input!
So for like 3 days I could barely move it, and then it went back to normal, and its been fine since. I'm going to wait until it gets bad again to get it fixed.
Old Jul 12, 2007 | 02:21 PM
civic8888's Avatar
civic8888
Fluid is ok
