Front license plates screw threads stripped
Old Oct 11, 2002 | 10:09 AM
caylan's Avatar
caylan
Default Front license plates screw threads stripped
my Front license plates screw threads are stripped & i can't mount the front plates on with screws.
I know from my previous 92 Si, that there is a front plate bracket that can be mounted onto the front bumper.
Right now, my car lacks that bracket & only has those 4 screw holes which are all stripped by the previous owner.
Any suggestion..cause w/ the snipe going around, I don't want to be too much of a troublemaker right now.
Thanks for any suggestions.
Old Oct 11, 2002 | 03:21 PM
Snoopy's Avatar
Snoopy
been there done that
get some zipties
Old Oct 11, 2002 | 03:30 PM
whiteEJ8's Avatar
whiteEJ8
you can replace them. The things that your screws go into can be pryed off from the back. You'll have to remove your bumper. I know because I had to pry mine off when I shaved my license plate holes. Im assuming that honda sells those. Whatever the hell they're called.
Old Oct 11, 2002 | 03:40 PM
str8edgexx's Avatar
str8edgexx
I had this problem about 3 months ago when I had to put new plates on my Mom's Integra. The back brackets on the bumper broke, and the screws wouldn't come out. Basically, what I did was take the bumper off, allowing me to access the back of the bolts. I fought with the a little bit and finally got the remnants of the bracket off, and got the bolts out. At that point, since the brackets were gone, I had to devise a way to put the new bolts back in. Basically, all I did was get a new bolt, and new nut, and 2 washers. I put the bolt and one washer on one side of the bumper (along with the new plate) and then the nut and the other washer on the back side. It worked out perfectly. It was a major pain in the ass (considering initially I thought I was just gonna change a licence plate), but it worked out perfect.
Old Oct 11, 2002 | 07:02 PM
umop-apisdn's Avatar
umop-apisdn
Allergic to vitamin D
Bad thing is, you'll probably half to buy the whole front bumper for two threaded plate-thinghys! Honda can sizzle my dizzle.
Old Oct 12, 2002 | 10:02 AM
caylan's Avatar
caylan
Default thanks for the suggestion & tips guys!
I'll see how much of a b_!_tch removing the bumper is & take it from there.
Else the zip ties look like a gr8 idea!
Old Oct 12, 2002 | 10:16 AM
crucial Si's Avatar
crucial Si
Banned
what color is that on your repainted Si?
Old Oct 12, 2002 | 10:56 AM
caylan's Avatar
caylan
Default I'm the 2nd owner but the 1st owner said that he painted
It "the new Si Blue".
I'm not experience w/ the differing shades of Honda blues.
Not sure if that's eternal or electron or something else. What do you think>? Circa 99 Si Blue?
Old Oct 12, 2002 | 12:53 PM
whiteEJ8's Avatar
whiteEJ8
electron blue pearl:thumbup:
