LSD Question
Old May 20, 2007 | 11:33 PM
turbogeo's Avatar
turbogeo
Default LSD Question
My next mod I plan for my Sol is to get limited slip. I have always wondered the pro's and con's to Quaife vs. swapping a D15B transmission that has LSD already. It will be going into/replacing my D16Z6 tranny.
Old May 21, 2007 | 06:53 AM
Fuse's Avatar
Fuse
Lsd helps you plant both tires in the strait away and helps launching however it can hurt you in the turns. Both tires in a turn rotate at different speeds a lsd in design trys to prevent you tires a rotating at different speeds so you don't spin one tire.
All and all I think its a +
Old May 21, 2007 | 08:25 AM
Civic2Scooby's Avatar
Civic2Scooby
LSD does not hurt you in the turns, in fact that is where it helps you the most. It keeps the outside wheel on pace with the inside wheel via mechanical, viscous, clutch type means. LSD applies power from the wheel that is slipping to the other wheel that has more traction. When turning the outside wheel will have the most traction as the inside wheel has a greater tendency to lift.
Old May 21, 2007 | 08:38 AM
raiden571's Avatar
raiden571
turning u inside out
its a great mod in my opinion. i wish i would have invested in one a while back, im looking at buying one mid-summer if my cash flow is sufficient, if not im selling blood and semen
Old May 21, 2007 | 10:18 AM
turbogeo's Avatar
turbogeo
I know what LSD does...
I am wondering if I should go with Quaife or should I get a JDM D15B tranny.
Old May 21, 2007 | 11:41 AM
Running925's Avatar
Running925
Your Powder Coater
If you plan to put more than 200-250lbs of Torque through that tranny then get the quaife.
btw.. if my new LSD wasn't all the way inside my tranny right now covered in oil, i'd give it a big slobbery kiss coz it's amazing! I love it!
Old May 21, 2007 | 11:50 AM
turbogeo's Avatar
turbogeo
Well I'm running 190ft/lb right now, and that is on a stock block. I plan on eventually putting more than 250.
Old May 21, 2007 | 03:56 PM
Snoopy's Avatar
Snoopy
been there done that
get the quaife. it has a lifetime warrenty. definitely worth it if you can afford it.
Old May 25, 2007 | 06:24 AM
rays>eg's Avatar
rays>eg
I have oem honda lsd in my tranny an its great in turns an luanching . Just beware of certain fluids . Kaaz has a good additive an stick with h.m.t.fluid .
Old May 25, 2007 | 09:17 AM
raiden571's Avatar
raiden571
ya, get the quafie if u have the money, obx lsd's work just fine
