clutch in, engine stalls
Old May 2, 2007 | 06:47 PM
g2_teg_na's Avatar
g2_teg_na
^ Visual Learner
Default clutch in, engine stalls
Well when im driving down the road and i go to slow down, when i put the clutch in the RPMs drop real low and then come back up to around 1200. Sometimes, if the clutch is pressed in around 3000 or higher, the RPMs will drop and the car will just stall. It starts right back up, but this is a big issue! any ideas?
BTW, this is a b18c swap in a 94 civic.
Old May 2, 2007 | 06:53 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
What ECU are you running? How light is your flywheel?
I was having the same issue with my car. I was stalling with a 9lb flywheel only after the car was warmed up. After I was tuned, the problem went away, so I speculate it was a fuel problem (too rich/lean in that portion of the map).
Old May 2, 2007 | 07:13 PM
g2_teg_na's Avatar
g2_teg_na
^ Visual Learner
hmm. well i have a 7.5lb flywheel. and i have a hondata s100 basemap installed in a p28.
that sounds like we had a similar issue.
anybody else heard of anything like this?
Old May 2, 2007 | 07:26 PM
Running925's Avatar
Running925
Your Powder Coater
yes that can definatly be the problem. you have altered the rotational weight which will require an adjustment for compensation in your fuel map & possibly a slight timming change due to the weight change.
Noticable difference, especially at idle.
obviously it would be more promenent after the car is warmed up due to the lower rpm's that it would be sitting at durring this time vs. cold start.
Old May 3, 2007 | 04:49 AM
g2_teg_na's Avatar
g2_teg_na
^ Visual Learner
well...i dont have a FITV installed at all. i plan on doing that today. it idles at a steady 1200. does anybody think maybe the power booster would have anything to do with it? i had been having issues with the brakes for awhile and i adjusted the brake booster and fixed it. but now that im able to drive the car this problem has come up.
Old May 3, 2007 | 05:29 AM
Running925's Avatar
Running925
Your Powder Coater
what exactly did you adjust on the brake booster?
Old May 3, 2007 | 01:15 PM
menappi's Avatar
menappi
I've read a lot about people with lightened flywheels having this happen. Do you need to tune to compensate for the lightened flywheel?
Old May 3, 2007 | 01:35 PM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
Clean the screen on your IACV
Old May 3, 2007 | 02:24 PM
g2_teg_na's Avatar
g2_teg_na
^ Visual Learner
i adjusted where it connects to the pedal. It wasnt on all the way and was making my brakes drag BAD. There wasnt any free play in the pedal at all. now theres about 5mm.
that was done before the motor was put together and installed.
Old May 4, 2007 | 08:34 AM
g2_teg_na's Avatar
g2_teg_na
^ Visual Learner
anymore ideas?
