question about 97 honda civic 4 door dome light
Old Apr 25, 2007 | 03:12 PM
puffy's Avatar
puffy
bow down to king puffy
Default question about 97 honda civic 4 door dome light
The light will not go on when door is open. It works when the light is on ON position but when its in the middle it will not go on when door is open. Any thoughts?
Old Apr 25, 2007 | 03:14 PM
AcuraFanatic's Avatar
AcuraFanatic
There's a toggle in the door jam. Perhaps the wire has corroded. If it does it for all 4 of them, check fuses (unlikely because other electronics would probably be affected) or I dunno
Old Apr 25, 2007 | 03:17 PM
AP2's Avatar
AP2
Moderator Alumni
Yes, check the toggle as it may get stuck at times.
Old Apr 25, 2007 | 03:18 PM
buy a new civic h:
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Also, I've had a door switch die on me with the Integra.
The plastic pin split and the spring... well.. sprung out. h:
Old Apr 25, 2007 | 03:35 PM
TheOtherDave™
Apathy Kills
Moved to Civic / Del Sol / EL. :ToDspin:
Old Apr 25, 2007 | 03:39 PM
cpvdh's Avatar
cpvdh
trim level?
keyless entry?
stock stereo?
i have had this issue when my keyless was freaking out on me
Old Apr 25, 2007 | 04:22 PM
Hondaman's Avatar
Hondaman
Black Pearl
My first questions would also be do you have the stock radio in it? If not, you probably lost the dome light function when the radio was removed.
Old Apr 25, 2007 | 08:10 PM
puffy's Avatar
puffy
really? It has some aftermarket radio. Why would radio affect dome light?
Old Apr 25, 2007 | 10:06 PM
cpvdh's Avatar
cpvdh
96-98 civics run the keyless entry and alarm throgh the stock head unit
if it is removed then the dome light along with keyless and alarm will not work correctly
was it working previously and just stopped working one day, did you mess with the stereo recently?
