help mee
Old Apr 19, 2007 | 11:56 AM
salkris's Avatar
salkris
salkris
Default help mee
have high air flow from the breather line placed on the head cover and i found some oil inside the intake manifold duct, and when i open the oil cap during engine running oil vapor and small oil droplets came out, is this normal or i have problem? my engine is B16A2
Old Apr 19, 2007 | 12:51 PM
KaoticBRD's Avatar
KaoticBRD
Is there air pressure blowing out when you take the oil cap off.
Old Apr 19, 2007 | 03:26 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
If the vapor is excessive, there is a problem. Otherwise, it is normal crankcase pressure caused by the movement of the rotating assembly.
Typically, it is perfectly normal to see a bunch of oily/greasy build up in the intake manifold because vacuum pressure causes those oil vapors to be sucked into the engine and harmlessly burned.
Old Apr 21, 2007 | 01:29 PM
salkris's Avatar
salkris
salkris
yes theres a pressure when i open the cap
Old Apr 22, 2007 | 01:37 PM
Provocateur
On permanent hiatus
Compression is leaking past the rings somehow into the crankcase causing that pressure. You should perform a leakdown and compression test to see if your rings are the culprit.
