Suspension On An EK9
Old Apr 19, 2007 | 05:21 AM
uo959's Avatar
uo959
Default Suspension On An EK9
I have a 99 Civic...What should I get suspension wise??? I'm getting H&R Race springs w/ some Tokico's(hp's or illumina's) and probably camber kits in the front and rear..What else??
Old Apr 19, 2007 | 07:38 AM
Wharbone's Avatar
Wharbone
For the H&R race springs, definitely get the camber kits. They are really low. I would really recommend the upper control arm style of camber kit for the fronts. Skunk2 and OmniPower both make these. I am using the Omni's.
What all are you looking for in other aspects of your suspension? What is your budget?
Old Apr 22, 2007 | 08:34 PM
uo959's Avatar
uo959
I would save up for everything...I want decent everything...I want to be able to take corners with out everything shifting to one side in my car.
Old Apr 22, 2007 | 09:56 PM
Outxider's Avatar
Outxider
X-Motoring
the best bang per buck is would be to contact collin/adam at weaksauce.org and order yourself the ground controls/koni yellows package, and you can get it with custom spring rates. fully adjustable ride height and damping. for camber kits, i would recommend the skunk2 pro series front and rear camber kit.
it really depends on what are you gonna do with the car, ie autocross, hpde, drag, ect. front/rear sway bars and polyurethane bushings would be good upgrades to look into.
Old Apr 23, 2007 | 07:22 AM
uo959's Avatar
uo959
I dont really want coilovers because I have no use for them and lowering springs are cheaper...I'm just using it as a daily driver
Old Apr 26, 2007 | 04:57 AM
twinring's Avatar
twinring
I went with that lowering spring stuff and it was a headache. listen to someone whos done it 3 times, get yourself a dedicated matched coilover shock, like JIC FL series, short throw suspensions are the only way to go low.
Old Apr 26, 2007 | 09:23 AM
Outxider's Avatar
Outxider
X-Motoring
jic's are overpriced trashy coilovers. first they are too stiff for the streets and their quality sucks. to the op, im telling you, the groundcontrols/koni yellows will be your best bet. i just installed a set on my friends eg, spring rate 400f/275r, konis set to full soft, the ride is awesome. it was smooth similar to stock. spend a little bit more and do it right the first time and you will thank me later. if i didnt have my tein flex, i would get the gc/koni setup in a heart beat.
Old Apr 27, 2007 | 04:52 AM
uo959's Avatar
uo959
What about the Tokico Blues with the springs they come with?? And what about all the braces and sway bars and stuff??
Old Apr 27, 2007 | 05:53 AM
Wharbone's Avatar
Wharbone
Tokico Blues are just OEM replacement shocks. I'd get a performance shock.
For the other stuff, you will most feel a difference with sway bars. I'd get the ASR subframe brace and either the 22mm or 23mm ITR rear sway bar w/ poly bushings if it were me. You typically won't notice a huge difference w/ regular strut braces and lower tie braces.
Old Apr 27, 2007 | 12:15 PM
uo959's Avatar
uo959
If I get the H&R Race springs...what shocks should I get??
