turn signal help
Hey guys..this is the problem im having with my 98 civic hx. no turn signals work front/back left/right, but they all flash with hazards on except front left. front left blinks though when i turn on/off my alarm. whats going on here. all fuses seem fine. thanks!
ok..so i eventually changed a few blown fuses, and indicators except front left are working now. i changed that bulb socket and it still doesnt work...any ideas? but of course now that ive gone through and changed fuses, my auto door locks dont work
HELP!! thanks!
HELP!! thanks!
Help...after changing a few fuses under the dash to fix an indicator problem (still not fixed) I managed to get the door locks to stop working. Anyone have any ideas of what I can try?? HELP!!
thanks.
thanks.
You have to make sure the fuses are put back absolutely correct. If not, your powerlock actuator might be out. Regarding your turn signal, there might be an issue with your signal switch on the steering column. Try cleaning the contacts.
