noob question
Old Mar 15, 2007 | 03:51 PM
JxHxB's Avatar
JxHxB
Default noob question
for a while i havnt known what certain things do or mean
so can some(non noob) fill me in
what does a sway bar do?
what does NA stand for(i think i know it means all engine but whats NA)?
what does camber do or camber kits?
what does i/h/e mean?
why do people add washers to raise their hood near the windshield?
why do people have tow hooks if their car is so low..that i fthey use them it will be scraping like crazy..probably without even having the wheels touching the ground?
is it true that if u have a b18c swap in an eg its hard to have a/c in your car?
what is a lsd tranny compared to hydro? what makes it better?
what is dyno tuning? and can it be done and be helpful on a stock engine?like a gsr?
if u can answer some of these questions ill be very happy
THANK YOU!
any additional noob info you wanna add will be appreciated
Old Mar 15, 2007 | 04:03 PM
Snoopy's Avatar
Snoopy
been there done that
http://auto.howstuffworks.com/car-suspension3.htm
naturally aspirated. no turbo. no supercharger. no nitrous. only what the engine itself can bring in.
http://en.wikipedia.org/wiki/Camber_angle a camber kit allows you to adjust this angle back to spec to reduce tire wear
intake, header, exhaust
because they think it helps cool the engine bay. it doesnt.
cause it's jdm :shake:
no
an lsd is a limited slip differential. a hydro tranny is simply the way the clutch fork is actuated by hydraulic pressure. an lsd keeps both wheels spinning in a straight line and sends power to the wheel with the most grip when going around a turn.
http://www.phearable.net/tech/efibeginnerguide.html
if there's anything you dont understand go to www.howstuffworks.com and search. lots of good info.
Old Mar 15, 2007 | 04:20 PM
JxHxB's Avatar
JxHxB
damn.that helped me a lot!! seriously
thanks man.
these stupid questions always help me alot.
