Noise coming from engine at 3450 RPM-3550 RPM
Old Jan 22, 2007 | 05:51 PM
avangusva's Avatar
avangusva
Default Noise coming from engine at 3450 RPM-3550 RPM
It sounds like a metal on metal contact, and possibly a loose metal part hitting another metal part. It only happen at around 3500 RPM on my 99 civic EX. Any ideas?
Old Jan 22, 2007 | 08:11 PM
jordanhxc's Avatar
jordanhxc
VTAK!!!!!
......Just Kidding
Old Jan 23, 2007 | 03:34 AM
lowbrow's Avatar
lowbrow
12:00AM Atlanta time...
Heat shield from your exhaust manifold? I had the same issue with my old 97 LX once... just ripped it off and stopped the problem.
Old Jan 23, 2007 | 06:56 AM
raiden571's Avatar
raiden571
turning u inside out
possibly needs a valve adjustment, but im leaning toward the heat shield idea.
kind of hard to diagnose a sound over the internet
Old Jan 23, 2007 | 12:47 PM
avangusva's Avatar
avangusva
Is anything going to be afected if i remove said heat sheild? The one right behind the radiator, on the exhaust manifold?
Old Jan 23, 2007 | 03:17 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
It won't hurt anything, you'll shave off 13 ounces y0!! :irock:
Old Jan 23, 2007 | 05:03 PM
project_hatch's Avatar
project_hatch
Power by Uncle Ben's Rice
only thing it does is reflect the heat from going towards the radiator, I run a header with no header wrap and have never over heated so it would be fine if you took it off.
Old Jan 24, 2007 | 07:30 AM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
sounds like heat sheild to me.
I've removed most of mine
Old Jan 24, 2007 | 08:23 AM
Line7's Avatar
Line7
Platinum Member
If its not the heat shield, its probably your catalyctic. Lift the car and have a buddy listen to what it is while you rev.
