Idle Problem plz help
Old Jan 22, 2007 | 01:07 PM
paintball487's Avatar
paintball487
Default Idle Problem plz help
Hi all,
I have a 94 Del Sol 1.6 L VTEC Modle and it has a bad surging problem with the idle...It has a few mods to it....intake, exhaust, MSD Blaster Sc coil.
Any way, the surging goes between about 1,000 Rpm and 1500 Rpm. I have replaced both the IAC Valve and the Fast Idle Thermo Valve... niether one made a difference. I litterally replaced both, started the car, drove 10 feet and it started surging. I have no clue what else could be causing this. Some body plz help. Thanx
Old Jan 22, 2007 | 01:11 PM
totalimmortal's Avatar
totalimmortal
MalleusMaleficarum
Do you have a CEL??
Old Jan 22, 2007 | 01:17 PM
Cousin It's Avatar
Cousin It
Check for a vacuum leak before doing anything else. Also check your base idle. If the base idle is too high it can cause surging. I had the same problem on my Accord and it turned out to be the o-ring on the idle adjustment screw going bad and allowing the screw to back out too far. Once I replaced the idle screw and established the correct base idle my surging went away.
Old Jan 22, 2007 | 03:35 PM
BeaterHonda's Avatar
BeaterHonda
I second Cousin It's diagnosis... i had the same thing recently and it was a leaking throttle body gasket.
with the mods you mentioned, if you did them yourself recently before this happened, there may be a vaccuum leak somewhere.
take the intake tube off and put your hand over the entire opening with your car running.... if it still runs its a definite vaccuum leak.
dont play with any of the factory settings until you know where the problem is!!!
Old Jan 22, 2007 | 03:49 PM
totalimmortal
MalleusMaleficarum
It should also be noted that we're not dealing with an Accord, but a Del Slo.
Opps, typo:reechy:
Old Jan 22, 2007 | 04:38 PM
gulfview's Avatar
gulfview
In addition to the above, next in line for checking are the THROTTLE BODY SENSOR and the MAP SENSOR.
Old Jan 22, 2007 | 06:28 PM
paintball487
HAHA del slo very funny LOL
ne wayz, ill run those tests and stay posted. Any other ideas are appreciated.
thanx
Old Jan 22, 2007 | 11:14 PM
Civic2Scooby's Avatar
Civic2Scooby
why would you just throw a new IAC and FITV into a car without properly diagnosing the problem? You are welcome in my shop anytime, you smell like money.
Old Jan 23, 2007 | 12:24 AM
Chefboiali's Avatar
Chefboiali
scrotal surge
:rofl:
I thought the same thing. Check your coolant level too.
