Civic emission problems
Old Jan 10, 2007 | 09:56 AM
vigalantyvillan's Avatar
vigalantyvillan
Emo hunting Crx driver!
Default Civic emission problems
Hey i was wondering if anyone knew any tricks to lower my idle emissions on a 95 civic d15 vtec? The required idle emissions it 1.2 @ and idle of 930rpms i ran a 1.25 so i was off 0.05 not much but enough to keep me from receiving tags.
Old Jan 10, 2007 | 10:08 AM
DarkSideAccord's Avatar
DarkSideAccord
Chidori-chan :love:
o2 sensor? seafoam?
Old Jan 10, 2007 | 10:20 AM
vigalantyvillan
Yea im currently running the seafoam. The engine is in my 88 crx and i replaced the stock exhaust manifold with an after market header. But i would imagine a point 0.05 emissions is so minuet that some small mechanical adjustment or fuel treatment would fix my problem...????
Old Jan 10, 2007 | 10:22 AM
dubcac's Avatar
dubcac
I
Oil change, spark plugs...minor tune up
Old Jan 10, 2007 | 10:25 AM
clickwir's Avatar
clickwir
Floppy Death! noES!!!
your only working with 1.2 anyway. It's already a small number.
Old Jan 10, 2007 | 10:31 AM
vigalantyvillan
true, true, i was thinking possible spark plugs maybe get some replacement NGK's and set the gap that should shave a little carbon. The o2 is fine recently replaced and yes it was properly installed. However it has been a while since the last oil change.....
Old Jan 10, 2007 | 01:28 PM
MTEng's Avatar
MTEng
plugs, cap, rotor, air filter, change oil and run a can of BG 44K through it (drive it hard). Use dealer parts.
Old Jan 10, 2007 | 04:07 PM
vigalantyvillan
Sweet thanks! Im going to try running alcohol and change out my plugs. I have already used some seafoam.
Old Jan 10, 2007 | 05:35 PM
ari_one's Avatar
ari_one
Oil & filter, plus air filter will most likely do it if you haven't changed any of them in a while. If you have a stock air filter, you can always try to run without an air filter but I wouldn't recommend it if there is any dust etc. around.
