Big Brake kit Recomendation
Old Jan 7, 2007 | 03:34 PM
Johnny X1900's Avatar
Johnny X1900
Thanks for the responses. You guys are probably right that they are not justified, considering I have no engine mods. I do plan on doing some engine modding some day, but I would like to improve its handling and stopping performance first for safety sake. (I know, Im sissy ).
My del sol is the one with the b16a3.
Old Jan 7, 2007 | 03:37 PM
2gr84u's Avatar
2gr84u
2gr84u
My Del Sol was making just under 300 hp before i sold it, and i was only experienceing mild dificulty slowing down after ripping on it, but i was still on stock pads. A simple upgrade to more agressive break pads is all you need
Old Jan 7, 2007 | 03:38 PM
Snoopy's Avatar
Snoopy
been there done that
new blank rotors, new aggressive pads, and new fluid is more than enough for anything you plan on doing. dont forget sticky tires as well. you can have the biggest brakes in the world but if you're tires suck ass you wont stop for shit.
Old Jan 8, 2007 | 06:14 AM
cookiecrips's Avatar
cookiecrips
I was planning on doing this since i plan on tracking my sol but it is an s type so what is better changing the back arms to si arms or getting the kit on fastbrakes that will convert the back to disc.
thanks
Old Jan 8, 2007 | 11:00 AM
Snoopy's Avatar
Snoopy
you can find rear disks from a junkyard for much cheaper than the fastbrakes kit. but the fastbrakes stuff is pretty complete.
Old Jan 8, 2007 | 11:49 AM
2gr84u's Avatar
2gr84u
2gr84u
thanks
I thought you had the Del Sol VTEC, that came stock with 4 wheel disk brakes. The Del Sol S has a d15 in it and you definently DO NOT need any kind of enhanced braking for that POS.
Old Jan 8, 2007 | 08:35 PM
little_chicken's Avatar
little_chicken
Little chicken~:>
hey!! dont knock the d15, it may suck but some us cant help it :cry: ........i out ran my friends 5-speed camaro with it, it cant be that bad
Old Jan 9, 2007 | 02:40 PM
cookiecrips
Mine is a type s i got screwed out of the si but i plan on putting some serious power into it.
Old Jan 19, 2007 | 11:32 PM
turbogsrsol's Avatar
turbogsrsol
i have a turbo gsr in my si making about 300whp at 9.5 psi and all i did was went with some drilled and slotted brembo's with semi metalic brake pads and braided steel lines and it almost stoppes as good as my roomates tt supra with project u's so its pretty damn good i think you are going to need alot more power to require a big break kit but dont get me wrong i would deffinatly sport one if the cash was there
Old Jan 21, 2007 | 08:45 AM
Johnny X1900
Like I mentioned b4, I plan on building this thing up in the future, and I am aiming for around 300hp. I should also mention that I have a 92 cx hatch with 142k miles. Once that engine dies, that b16 is going in there I will be getting a new motor for the Del sol. I have about a 5k budget to spend on the motor swap and buildup. For now, I am more concerned about safety and handling.
Thanks again for the advice guys.
