Service Manuals
I just figured he might get it the same way I did, by reading the Online Resources Thread sticky. Hondaman posted a link to that thread. It seems like no one wants to bother reading the stickies or search for anything. And I was in the mood to be a sarcastic prick.
same
v-card member alpha
I only made it to 60% last time I tried downloading a manual, this comp. has dial up(56k:boink: ) :chuckles:
I apologize for this is a little off topic but where is a good place to buy a cheap torque wrench? The cheapest I've found doesn't torque to low enough specs(I may be confused) to use on spark plugs, maybe not even for lug nuts. The $30 one I found would work but that's a bit pricey for me and it's HUGE!
actually you technically should torque spark plugs. Especially with aluminum heads as they have a higher rate of stripping out threads. But yes if you are familiar with thresholds than it is easier and more practical to tighten them without the use of a torque wrench.
I noticed the "free" Civic manuals on the UK website (linked to from this civic forum) were down the last few times I looked. You can buy CD versions from E-bay as low as $5-$6 bucks. That's what I did and they were fantastic.
William
98 Civic + 03 Pilot
William
98 Civic + 03 Pilot
Yep, it's called searching the net, and some of these members definitely need a lesson...
v-card member alpha
When I changed the plugs in my '92 EX I went by what the manual said, thread in by hand and then 1/4 turn. It also gave the torque specs for those so equipped of course.
The manual for the '90 Prelude Si I used to drive, and still miss, said to do 1/2turn.
I'm fairly confident that if I did that on my car I'd mess up the threads in the head. If not the first time, the 2nd.
But you would rather be safe than sorry, cause aluminum is soft, and the threads are easily stripped... I mean EASILY...
Get an online manual, I posted the link? :dunno:
