compression testing??
Old Sep 30, 2002 | 11:32 AM
oc_civic's Avatar
oc_civic
mcc racing
Default compression testing??
d16y8?? want to test compression... specific in structions would be helpful..
thanks
Old Sep 30, 2002 | 12:50 PM
SpeedRacerEX-R's Avatar
SpeedRacerEX-R
pull the ecu fuse, dissconnect the plugs to the distributor. Pull all the spark plugs. Put the gauge in the cylinder and turn motor over 4 times, watch gauge.
Old Sep 30, 2002 | 01:20 PM
oc_civic's Avatar
oc_civic
mcc racing
cool thanks a lot...
Old Sep 30, 2002 | 01:31 PM
Jkan2001's Avatar
Jkan2001
S2000 Pilot
or you can just pull the fuel pump fuse....but whichever works. Also from my experience you have to turn it over more than 4 times. I didn't get full compression when i only turned it over 4 times...i think i usually do about 6.
Old Sep 30, 2002 | 02:25 PM
oc_civic's Avatar
oc_civic
mcc racing
j k a n 2 0 0 1 [4:09 PM]: ughhh
j k a n 2 0 0 1 [4:09 PM]: have you never changed out a fuse?
X oc civic X [4:09 PM]: sure
X oc civic X [4:09 PM]: they are normally marked
j k a n 2 0 0 1 [4:09 PM]: duh'
j k a n 2 0 0 1 [4:09 PM]: they are all marked :-)
X oc civic X [4:10 PM]: oh ok
j k a n 2 0 0 1 [4:10 PM]: just look on the little plastic sheet in your fuse box that tells you which fuse is what
j k a n 2 0 0 1 [4:10 PM]: i think the fuel pump fuse is near the middle
j k a n 2 0 0 1 [4:10 PM]: anyways....just pull it out
j k a n 2 0 0 1 [4:10 PM]: so now you have the compression tester screwed in....the fuse pulled
j k a n 2 0 0 1 [4:11 PM]: anyways....at this point put your car to the on position
j k a n 2 0 0 1 [4:11 PM]: and try and start it
j k a n 2 0 0 1 [4:11 PM]: it will sound like it's trying to start but it won't be able to cause it has no fuel
j k a n 2 0 0 1 [4:11 PM]: hold the key on like you're trying to start the car
X oc civic X [4:11 PM]: ok cool
j k a n 2 0 0 1 [4:12 PM]: for about 6-7 clicks
j k a n 2 0 0 1 [4:12 PM]: u know how it sounds like when you are trying to start a dying car
j k a n 2 0 0 1 [4:12 PM]: and it won't start
X oc civic X [4:12 PM]: yeah
X oc civic X [4:12 PM]: definately
j k a n 2 0 0 1 [4:12 PM]: just hold it like that for a few seconds and at least 6 clicks
j k a n 2 0 0 1 [4:16 PM]: there are 3 rows of fuses right
X oc civic X [4:16 PM]: yeah
X oc civic X [4:16 PM]: maeks sense
X oc civic X [4:16 PM]: sounds familiar
j k a n 2 0 0 1 [4:16 PM]: like
j k a n 2 0 0 1 [4:16 PM]: XXXXXX
j k a n 2 0 0 1 [4:16 PM]: 3 rows of fuses
j k a n 2 0 0 1 [4:16 PM]: and some spare fuses off to the side
j k a n 2 0 0 1 [4:17 PM]: the fuel pump fuse is in the MIDDLE ROW
j k a n 2 0 0 1 [4:17 PM]: and it's 2nd from the very left side
X oc civic X [4:17 PM]: ok coool
X oc civic X [4:17 PM]: thats easy
j k a n 2 0 0 1 [4:17 PM]: it's a 15A
j k a n 2 0 0 1 [4:17 PM]: correct....
j k a n 2 0 0 1 [4:17 PM]: i forgot how many holes there are in each row of fuses
X oc civic X [4:17 PM]: what kinda numbers am i looking to see on the testor
j k a n 2 0 0 1 [4:17 PM]: i got 190
j k a n 2 0 0 1 [4:17 PM]: 's
X oc civic X [4:17 PM]: all the way across
j k a n 2 0 0 1 [4:18 PM]: just make sure you get within 10 of each cylinder
X oc civic X [4:18 PM]: how much
j k a n 2 0 0 1 [4:18 PM]: yah i got pretty much 190 all teh way
X oc civic X [4:18 PM]: ok
j k a n 2 0 0 1 [4:18 PM]: but yeah that's pretty much it
j k a n 2 0 0 1 [4:18 PM]: just make sure you click it over enough times
X oc civic X [4:18 PM]: so like 188-198 would be ok
j k a n 2 0 0 1 [4:18 PM]: or you'll get low compression numbers
j k a n 2 0 0 1 [4:18 PM]: yeah 188-198 is borderline
X oc civic X [4:18 PM]: my friend said 7-9 times
j k a n 2 0 0 1 [4:18 PM]: yeah usually within 5
j k a n 2 0 0 1 [4:18 PM]: but 10 isn't too bad
X oc civic X [4:18 PM]: what is the "norm"
X oc civic X [4:19 PM]: like 190? 200?
j k a n 2 0 0 1 [4:19 PM]: around 190, 190, 190, 190
maybe if someone needs a slightly more detailed explannation they will find this thread by using the search feature...
thanks again for the help
Old Sep 30, 2002 | 02:52 PM
Jkan2001's Avatar
Jkan2001
S2000 Pilot
No problem...always glad to help a fellow HAN member out :thumbup:
Old Oct 1, 2002 | 02:17 AM
SpeedRacerEX-R
Ummmm, if it doesn't build in 4 strokes, you've got problems. 4 turns always works for me, whether it be a v8 or a 4 cyl. I got 205 in the B18C and 195 in the d16z on 4 cranks.
Old Oct 1, 2002 | 09:16 AM
Jkan2001's Avatar
Jkan2001
S2000 Pilot
probably depends on your compression tester also....in any case we've always had to do about 6. When we did 4 on my friends JRSC prelude it didn't go up to the other cylinder #'s so we did it again with a few extra cranks and they were all within 5 of each other.
Old Oct 1, 2002 | 10:06 AM
SpeedRacerEX-R
That's because it was having problems building compression. Not a serious issue. And if 1 cylinder didn't go up, you probably have a sticking valve. You don't keep cranking on it till it gets up to a number you like, that's why you do the test.
Old Oct 2, 2002 | 01:50 PM
derf's Avatar
derf
Spec5
you also got problems if the cylinders don't have basically the same compression
if you have low compression how do you fix it? i haven't done a compression test in a long time
