When u painted the bay did u pull everything out?? Looks great man, i Wish i had the time to do a wire tuck. What turbo u running again?
I masked off the quater panels, masked off the clutch and brake reservoir, the wiper motor shroud or whatever you want to call it, pulled the wires out of the bay and under the frame, masked off my vacuum manifold, and steering rack. Then I sanded with 380 wet/dry paper, put down some 98 cent primer in a can, sanded with 400, primered again, sanded with 600, then two coats of Duplicolor flat black.
I have to re-sand and paint a few areas that got fucked up when I put the motor back in.
I am. I'm running my tune from when I had 10.5:1 compression so the A/F is still in a safe zone until I get time to tune it later this week,
your bay is still in primer, you should paint it
Lookin good, it looks like you cleaned up your injector wires and I see you rerouted the oil feed. Clean looking engine bay, I like it
Flat black>*
Yeah I did a little more on the tuck. There is no visible wires, just the necessary cables and fluid lines. I didn't have the motivation to hide all that other bullshit.
