Engine break in....
Old Sep 25, 2006 | 11:31 PM
Omniscient's Avatar
Omniscient
warm butter on toast
Default Engine break in....
How? Tony, David, Schmoo, Eric? hmm?
Old Sep 26, 2006 | 05:21 AM
Running925's Avatar
Running925
Your Powder Coater
Anything posted in this thread will be concidered theory, based on facts.
this is the method that i believe works well & i've had no problems with it...
let it warm up & cool down a few times while it's in the garage as you check it over for leaks.
then take it out for a drive, b4 u hammer on it make sure u can still shift through the gears & everything is running properly.
then use second & third, run them out the rpms till about 5 or 6k & let it rev it self down, don't hit the brakes & push the clutch pedal in coz u'll be defeating the purpose. When you let the engine rev down, it's allowing the oil rings to do a good job pulling all the oil & everything off the cylinder walls.
i'd say drive it around for about a half hour all cautious like & letting the engine very in rpm's a lot, but basicly just get out there & put it under load so that the rings will wear a little & seat them selves.
i know someone will come in here & tell you to baby it, but to be totally honest with u, if it's gonna break, it's gonna break... i run the hell out of my motor & i treat it right when it comes to maintenence (changing fluids). It likes it!
anyways, change your oil the first 50miles to get all the assembly junk & any possible break in shavings out of it.
do the same at 500 / 1000 & then your normal cycle
Old Sep 26, 2006 | 05:52 AM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
DONT BABY IT, its one of the worse things u can do, the first 20 miles is the most critical, Then when u still have some cross hatching to "file" the rings to get a 360 seal. This is what i used on David Sol motor....http://www.mototuneusa.com/break_in_secrets.htm
Old Sep 26, 2006 | 10:24 AM
Omniscient's Avatar
Omniscient
So will the exhaust smoke like crazy until the rings seat themselves?
Old Sep 26, 2006 | 10:42 AM
Civic2Scooby's Avatar
Civic2Scooby
drive it hard and seat the fuckin rings....anybody who tells you to baby it should get kicked in the nuts.
Old Sep 26, 2006 | 10:54 AM
Running925's Avatar
Running925
Your Powder Coater
your cylinders are perfectly round (you had it bored & honed)
you should have minimal smoke!
it might smoke a little till the pistons warm up & expand to the correct clearances (normal for forged internals).
Old Sep 26, 2006 | 11:11 AM
Omniscient's Avatar
Omniscient
So basically burp the coolant system then drive it for the ring seating?
And will non-synthetic 10w30 do the job?
Old Sep 26, 2006 | 12:38 PM
HatchVX's Avatar
HatchVX
I would use 5w30, but thats me.
Old Sep 26, 2006 | 12:40 PM
Omniscient's Avatar
Omniscient
Eh, I'll try it. During the summer if I ran 5w30 and it was like 90 degrees outside the oil would work its way through my turbo seals. Now that it's a little cooler out it might not.
Old Sep 26, 2006 | 12:42 PM
Snoopy's Avatar
Snoopy
been there done that
personally, if it was a rebuilt motor i would have it broken in on the dyno
