Using p28 on d15b vtec but get p08 maps?
I'll charge ya $10 for my time and then you pay shipping back and forth. You need to get a chip kit ($25 from moates.net) and that should be all I would need. If you want to buy the chip burner and burn the chip yourself, you could do that. I could, instead, burn you a chip with my chip burner, but I need to download uberdata and see if they have P08 roms available because Crome doesn't.
thats the fastest way to ruin your ECU as a quality tempature controlled iron is needed to do the work. if your doing this to learn then fine, if not it's faster and cheeper to get t6he P08 and the 1 wire O2 or use the 4 wire w/o the heater hooked up.
Thanks for taking the time to help me.
If you bump into what's needed, please let me know. I could Pay Pal you the $, and pay you more than $10 for your troubles :hs:
Secondly, I know this P28 works, and I'm just not in the mood to get a P08 DOA from anywhere.
Here is the chip burner:http://www.moates.net/burn1-flashnbu...mmer-p-48.html
I still need to download Uberdata and see if there is a P08 map available. I will do so later today and let you know if this will work.
Here is the chip kit: http://www.moates.net/honda1-honda-e...-kit-p-42.html
This entire ordeal is Greek to me, so I'm glad you guys have my back. I'd be getting bent over anywhere else smelling like noob :hsughr:
I will look around on pgmfi.org and see if I can find a stock P08 map for Crome.
