Bouncing idle. help....
Old Sep 8, 2006 | 07:21 PM
jay redhouse's Avatar
jay redhouse
Default Bouncing idle. help....
ok i have a 92 cx with stock motor with just aem intake and full cat-back exhaust... the problem is the car does not idle smoothly and the speedo does not work.. i got this car just recently and it did this already.. the guage cluster does not work except for the gas and temp gauges and signal also.. no tack in the dash and the car came with an aftermarket one that didnt work either. got it to work after searching few times on here.. so now the car starts up fine but after like 5 seconds the idle jumps to 1500 and back down.. i tried searching on here but no luck to the regular idle then the jump, blows a little smoke when idleing... and also the car stinks like gas and exhuast, any clues..thanks for any help...
Old Sep 8, 2006 | 08:49 PM
jdmeg6hatchy's Avatar
jdmeg6hatchy
i
try cleaning your IACV.
Old Sep 8, 2006 | 09:07 PM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
If it happens on a cold start, it is the FITV (Fast Idle Thermal Valve)
If it happens after the car reaches operating temp, it is the IACV (Idle Air Control Valve).
It sounds like the FITV has backed out.
Old Sep 9, 2006 | 10:26 AM
jay redhouse
alright thanks guys ill try and clean the iacv and check the fitv. i will post up when i do this and see what happens.. thanks..
Old Sep 10, 2006 | 04:06 PM
jay redhouse
stopped the jumping idle but now i need help with the smell coming into the cabin from the engine bay.. help me please....
Old Sep 10, 2006 | 04:37 PM
asiandoood's Avatar
asiandoood
what did you do to stop the irratic idle?
as for the smell, do you have an exhaust leak?
Old Sep 10, 2006 | 06:55 PM
jay redhouse
I just cleaned out the iacv and throttle body... that might be the thing cause the exhaust does hang pretty low... ill chech that out tomarrow... i ill see what happens tomarrow..
Old Sep 11, 2006 | 07:03 PM
jay redhouse
well now i have another problem, i broke the timing belt trying to get the crank pulley off... the water pump was leaking and now i have to get a timing belt and cant see if the exhaust is leaking.. i think it was the charcoal canister also so i changed that out with one i had lying around.. well see what happens when i pick up another timing belt...
