how do i fix engine code 43 on a 92 civic
swapped my old engine out nothing special saving for something big everything went cool until i hit the freeway that the check engine light came on about 85mph check the code it threw out 43 fuel supply or something like that has anyone come across this prob. before any help would be great thanks
only components that should ever need replaced in the fuel system would be...
pump
filter
injectors
(once in a million years, the FPR)
find your problem, replace the correct part
*edit: or put gas in your gas take if you did this while it on on E
pump
filter
injectors
Did you figure it out?
My car (92 4dr LX-stock) didn't start after a half hour drive and two minute park last week, I reached up and tapped the main relay. It started and worked fine for a few days.
The while driving, I get the same code. I cleared the code by removing the fuse and haven't had it come back, yet.
Mine has the original relay and pump with 360,000 miles. If you figure it out please post back diagnosis and results.
