running without vtec
Old Aug 10, 2006 | 11:31 AM
Eghatch19's Avatar
Eghatch19
Default running without vtec
question if you run a b18c without vtec hooked up can that damage the vtec..?
Old Aug 10, 2006 | 11:32 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Nope, but how do you mean not hooked up? Just not having it wired? Your ECU will likely throw a code if you don't wire it.
Old Aug 10, 2006 | 11:44 AM
ariza034's Avatar
ariza034
SuMaDiNaC
one question westcoast will it be able to rev past 5.5k if its not hooked up? or how does it work out
Old Aug 10, 2006 | 11:54 AM
westcoaststyle
Of course it will. VTEC is actuated by oil pressure and a couple other checks I believe to ensure you're at a certain speed and not in reverse, but those are not confirmed to my knowledge, just Internet banter. Anyhow, when the oil pressure reaches the specified point and you're at the correct RPM (5200, I believe for a B18C1) little shafts in the lifters slide into a third lifter per valve pair and use a taller, more aggressive lobe on the cam. This is VTEC. Read more here: http://auto.howstuffworks.com/question229.htm
If your VTEC isn't working properly (or isn't hooked up) then the shaft's won't connect to the third lifter and VTEC will not engage, but you're not restricted to RPM's below VTEC.
Old Aug 10, 2006 | 12:13 PM
Snoopy's Avatar
Snoopy
been there done that
4400 to be exact
Old Aug 10, 2006 | 12:19 PM
westcoaststyle
Oh, then 5200 must be what I set mine to. Sorry about that :exnbp:
Old Aug 10, 2006 | 12:28 PM
Eghatch19's Avatar
Eghatch19
yea i just dont have it wired up ... im waitng on my p28 to come in also what the hell does IAB mean
Old Aug 10, 2006 | 12:31 PM
Snoopy's Avatar
Snoopy
iab's are the secondary butterfly valves in the gsr's dual plenum intake manifold. if you use a p28 and still have the stock intake manifold, the secondaries wont open at 5800 and could cause a lose in power.
another thing i read somewhere is that vtec wont engage below a certain throttle position. so even if you reach 4400 rpm but are under a certain throttle position, vtec wont engage. just something i heard. :dunno:
Old Aug 10, 2006 | 01:22 PM
OldSkoolF22's Avatar
OldSkoolF22
I'd hit it =P
B18C is 5400.. very easy to hear with aftermarket intake plenum and Short ram intake. VTEC wont open unless at WOT or close to it. VTEC needs the oil pressure supplied by nearly WOT or WOT to engage the cams.
4400 is just too LOW for VTEC. Hell my Civic EX engages at 5400 and thats just a little D16
PS- I disengaged VTEC when i supercharged it by blocking of part of the VTEC oil pressure solenoid. I just allowed the engine to stay in mild cam mode. After I removed the supercharger, I replaced it with a new VTEC solenoid, some aftermarket high lift cams, and it was all good again.
Old Aug 11, 2006 | 01:53 PM
Snoopy's Avatar
Snoopy
Originally Posted by OldSkoolF22
B18C is 5400..
4400 is just too LOW for VTEC. .
check your facts again. a stock b18c1 will engage at 4400. coupled with the intake secondaries opening at 5800, this makes for a smooth torque curve. now a b18c5 is somewhere around 5800.
