d16y7 help please
Old Aug 6, 2006 | 08:41 AM
PreludeSiprojec's Avatar
PreludeSiprojec
Default d16y7 help please
i have a 92 civic 4 door. and i just swapped a d16y7 into it.
i am very new to hondas, i am used to working on dsm's.
so any help would be much appreiciated.
so here is my problem, the motor is in and the wiring harness is all plugged in, i am not sure what motor the harness is from but everything pretty much matches up except the clips to the 4 injectors, i cut them off and rewired the clips that came with the motor (that was the only part of the wirring harness that came with the motor, the injector wires)
i made sure to match the colors with the original clips
other than that pretty much everything connected fine. after we fineshed connecting everything i tried to start it. it didnt even turn over, it didnt even try.
the battery is good and i really dont know why it wont even ingauge the starter...
if you know why or even if you just have some ideas please let me know how i can fix this.
do i need a new wiring harness?
would i need the ecu from the 96 civic that the motor came out of?
Old Aug 6, 2006 | 09:15 PM
mini-me civic's Avatar
mini-me civic
wat computer are u running?
Old Aug 7, 2006 | 12:21 AM
PreludeSiprojec
oh sorry, its the d16y5, my bad. and after messing with it today i found out that it does start, i did the ignition bypass (wrench and the starter)
and it started right up, but for some reason the key will not engauge the starter... the car does have a factory security system in it, and a friend of mine says that it could be the reason its not turning over with the key ( i dont have a remote for the system or anything like that)
or could it just be the ignition is bad?
Old Aug 9, 2006 | 09:10 AM
swaggs21's Avatar
swaggs21
there was a recall for it in 2002, take it to honda and they will replace for free
Old Aug 13, 2006 | 10:25 AM
PreludeSiprojec
hey thanks man, i'll go do that
Old Aug 13, 2006 | 06:01 PM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
honda run's vin numbers on that kinda thing. the engine better be similar to what came with the car, or they won't honor the recall
Old Aug 15, 2006 | 04:30 AM
swaggs21's Avatar
swaggs21
agreed, but usually (depending on the dealer) you can talk them around it.
Old Aug 15, 2006 | 05:13 AM
Running925's Avatar
Running925
Your Powder Coater
check your engine grounds, if you didn't put them back on then the starter really doesn't have a grounding point, there for can't complete the circuit when u turn the key.
Old Aug 16, 2006 | 01:23 PM
PreludeSiprojec
alright, thanks for the info guys,
its deffinatly not the grounds, because when the kid i bought the car from comes over he touches some wires together and then it dissarmes the security system and the key starts it.
Old Aug 23, 2006 | 01:23 PM
jrw1818's Avatar
jrw1818
hey i'm new to the d16y5.. are they good motors?? are they better then the b series? i wouldnt think so, so why wouldnt you just put the b-series motor in?
