SUpercharge
Old Jul 30, 2006 | 01:55 AM
ReVenGe's Avatar
ReVenGe
you are a liar...next.
own3d
Old Jul 30, 2006 | 06:24 AM
Chem Geek's Avatar
Chem Geek
H22A powered EH2!
Jackson Racing super chargers can be good if setup right on DOHC VTEC motors, although they don't have the expandability that turbos do. On SOHC's they're a waste of time, maybe if they had the same size blower as the DOHC versions, but alas they don't. If you're staying SOHC, go turbo.
Old Jul 30, 2006 | 10:21 AM
goon54's Avatar
goon54
i'd get a Vortech SC on DOHC but since ur SOHC, u arent gonna get impressive #'s at all. search this forum for turbo'ed d series. there are a few happy campers with a boosted SOHC especially 2gr84u recent thread
Old Jul 30, 2006 | 11:01 AM
pomansouth's Avatar
pomansouth
vortec superchargers have a much better design, If the charger is geared correctly, it will make more boost faster than any other charger. I have a friend that makes 14lbs of boost at 2200 rpms and it only builds from there, redline at 8700 it makes 26lbs...uber fast... more torque that a sti out of a corner, fun stuff...
Old Jul 31, 2006 | 05:49 PM
Chem Geek's Avatar
Chem Geek
H22A powered EH2!
They have a different design, which is not inherently better. Sure you can get cooler IAT's, but with an intercooler so can the positive displacment blowers. And, by design a positive displacement blower makes boost instantly. No building, it's there all the time. To get a centrifugal to make boost down low, as you suggest, you rev the snot out of it, and like you point out it makes 26lbs up top then. You can get 10psi on the low end with a positive displacement, without having to run 25+ on top. Centrifugal chargers cannot by design make boost faster than a positive displacement charger, same way a positive displacement charger by design will never be as efficient as a centrifgual charger or a turbo.
For a d-series? Turbo all the way!
Old Aug 1, 2006 | 12:00 PM
Cursed's Avatar
Cursed
Ohk would i have to do mod to the enigne if i was to put a turbo on or what?????????
Old Aug 1, 2006 | 01:03 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
With this question, you need to search and read A LOT of threads and posts. So, start searching homemadeturbo.com is a good site.
Old Aug 1, 2006 | 01:41 PM
qtiger's Avatar
qtiger
You do realize that a vortec supercharger is just half a turbo on a stick, right?
