What all do I need h22 into civic.
I want to do a different setup then what I have right now. I want to put an H22a into my 96 ek civic coupe. Can someone tell me what all I need for this. Along with where to find the wiring info I will need. Thanks for the help....
You can find the info if you search...
https://www.honda-acura.net/forums/s...d.php?t=240079
theres a starter for you...
Motor mounts, tranny, axles, Motor (DUH), hammer, and welding job for the flange on the cat, wire harness for whatever OBD your running, shift linkage, radiator hoeses, good cooling system, get a better radiator and Fan, because think about it your cooling your little single cam or b series 1.5-1.8, 1.8 runs a little warmer with that civic radiator so imagine a 2.2 liter, seen it done it, DONE, AS far as wiring, just get wiring diagrams for the Prelude somewhere around the net, and some civic wiring diagrams, just use a prelude wireharness and put some skills to work,thats pretty much it someone correct me if im wrong
