Best strut bar for '97 Civic LX?
Thanks for all the replies. You've all been really helpful. Someone mentioned a sway bar; is that easily installed on a Civic like mine? Would it be better, for handling purposes, to invest in that instead of the lower tie bar? I guess there's an advantage to having both?
oh hey if you're interested in a lower rear tie bar, I have a brand new polished neuspeed rear lower tie bar... give me an email @ capyoda@hotmail.com if you're interested.
umm.. IMO rear lower tie bars compliments sway bars.. especially if the sway bar is thicker than usual (19mm +) the lower rear tie bar helps reinforce the subframe and prevents the thicker, stiffer sway bar from tearing the subframe away...
I'm not sure but does the 99-00 Si rear sway bar bolt right up?
I dont think the 97 lx sedans come with any rear sway bar...
aftermarket ones are kinda expensive though...
if the 99-00 Si bolt up easily, u should consider getting it.. shouldn't cost more than 80-100 bucks. (I think they're 13mm)
*edit*...if you look at the picture I posted above of my Neuspeed tie bar, you can see the Si sway bar right above it
ah cool.
I saw the sway bar in the pic, but wasn't sure if that was the stock ex's or what not..
I think I'll go along with 15mm, that makes sense.
80 bucks with endlinks too? thats cool.
yeah I think u should get the rear sway instead of other things, that will yield more result than anything else. it will definitely make things more neutral.
I got a 19mm rsx rear sway bar on my 01 civic, its a big up from my stock 12mm ex rear sway.
edit: i just checked the pricings, endlinks cost around 36 bucks each!! ouch. I wonder how you got it for so cheap. that was quote from dealer online anyway. my sister has a 98 lx sedan, I was thinking maybe I'll do that for her.
The endlinks cost just as much as the bar its self does...its crazy. Honestly, I think you should hook her up with it if you can. Check ebay or the classifieds here or any other sites you post on (I got mine off a kid on HT), or even thepartstrader. You should be able to pick it up for somewhere between $50-$100. You get that, and now you don't have to worry about a Christmas present for her :thumbup:
ah she's always "stop messing with my car"
but I'm sure if I slap this baby on she'll notice the much more neutral handling
I'll look around. there's one on ebay right now but I dont think it comes with the endlink.
just surprise her one day. Put it on, and don't tell her...it only takes a little while. Then, see if she notices anything or says something. Its not really messing with the car...it is a dramatic improvement. There is absolutely no downside to it....but then again, I know how sisters can be
i have the neuspeed upper front, neuspeed rear lower, and suspension techniques front and rear sways.. the most difference was the rear sway bar, hands down.. also the most expensive.. i got my neuspeed used from a guy for $60 shipped looks nice and is the most solid upper front you can get, aside from mugen and OEM. i had to drill to install my rear sway.. it is 3/4" thick.
In the pic, looks like you got some oil leak problem? :P
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX - SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Thanks again, everyone. If anyone knows where I can get my hands on an Si rear sway, let me know. For now, I'll check the places people have mentioned for the parts I requested. Thanks.
Schwa
12
Jan 12, 2006 11:57 AM
Tr0LL
Oct 26, 2004 07:25 PM
dchung1
Apr 27, 2004 02:41 PM
tbkonwso
Oct 12, 2003 10:06 PM
