odd radio / keyless entry
Old Sep 24, 2002 | 03:23 PM
ret's Avatar
ret
im dying inside
Default odd radio / keyless entry
im having some problems w/ my radio/keyless, first off the radio's vol. control is crapy as hell, it doesnt work right at all increasing the vol. sometimes goes down, other times it never works, it takes upwords of 3 min. to get the vol. adj. to where i like it. my other problem is w/ my keyless entry, it works in the same way as my radio, half-fast. one day it will work like a champ, others not at all. i relise that the keyless is controled by the radio unit, im wondering if this is common or not. any information would be great. thanks in advance.
Old Sep 24, 2002 | 04:14 PM
Bakeoff's Avatar
Bakeoff
wooooo woooooooooo
not a real common problem, but I'd recommend getting a different stock deck. Sounds like that's where the problem lies.
Old Sep 24, 2002 | 05:27 PM
derf's Avatar
derf
Spec5
i agree with bakeoff... do you have a 99-00?
Old Sep 24, 2002 | 05:46 PM
varyda's Avatar
varyda
if this is an aftermarket radio that is installed in your car then you might
not have gotten the right wiring harness when the radio wus installed
either by a friend or a shop. if it is an aftermarket radio try using the wiring
harness made for civics with keyless entry, if you got it installed at a shop
take it back and tell them to look at it.
if its the factory radio in the car then id say its time to swap it out for an
aftermarket one, unless the dealer wont charge you to replace & install a
new factory unit.
good luck,
hope this helps
Old Sep 24, 2002 | 07:21 PM
ret's Avatar
ret
im dying inside
im very sorry (new at this) i have a 96 civic, stock radio w/ keyless entry, i want to get this fixed so that i can get an aftermarket deck, however i want my keyless to work b4 i do the switch (so i can hide my stock radio in the dash) ill look in to getting a new stock radio from the junk yard or something, thanks all
buckeyeguy87
92+ Civic/EL & Del Sol
2
Oct 19, 2009 11:25 PM
acur8
RSX & 02-05 Civic Si
May 13, 2006 09:29 AM
ruuster98civic
9
Jan 23, 2006 10:58 PM
Rippa_MD
9
Sep 27, 2005 02:50 PM
Nightshade
Apr 5, 2003 09:42 PM
