this is my first post need some help
the person the put my swap said the he knew how to i just found out that he swap ls into civic but never done a GSR swap into a civic my car is a hx wap in a GSR he used the wired haness of my old engine first of my vtec don't kick in second he told me it was because my tps was broken so i got a new throttle body idle started to flutuated the i went to someone else he tolds it was the throttle body i got another throttle body and know my car don't idle regularly but stated accelerated at about 2500 rpm to 3000 rpm every time i start my car and it stay like that until i shut it off it don't go back down to it regular idling speed but before i change the thottle body it idle regular so now it stay like that oh and let me know if this happen to any body i checked my tranny and it was leacking throught a seal the driver side seal to be exat i put a new one in the mechanic the put in said that it went in too soft like it was to easy to put in the seal he din't need to used a hamer or anything he put it in with his hand so i say ok next time i checked the tranny the seal was ridind on the axle.
I take it your not from around here......Umm either IACV or FITV issues...could also be that some air got into the coolant lines...don't really no about the VTEC issues......and i new seal for the axle should fix your leak problem.
got a new seal same thing happend with this one like the last one I used some stuff to clean my cooling system and is still the same and I bought an used aicv off of Ebay put it on thats went my car stop idling wear and started to stayed accelerated at 2500-2000 rpm
Originally Posted by blackcoupe
the person the put my swap said the he knew how to i just found out that he swap ls into civic but never done a GSR swap into a civic my car is a hx wap in a GSR he used the wired haness of my old engine first of my vtec don't kick in second he told me it was because my tps was broken so i got a new throttle body idle started to flutuated the i went to someone else he tolds it was the throttle body i got another throttle body and know my car don't idle regularly but stated accelerated at about 2500 rpm to 3000 rpm every time i start my car and it stay like that until i shut it off it don't go back down to it regular idling speed but before i change the thottle body it idle regular so now it stay like that oh and let me know if this happen to any body i checked my tranny and it was leacking throught a seal the driver side seal to be exat i put a new one in the mechanic the put in said that it went in too soft like it was to easy to put in the seal he din't need to used a hamer or anything he put it in with his hand so i say ok next time i checked the tranny the seal was ridind on the axle.HOLYSHIT!!!!
Cananyoneunderstandortranslatethisforme?
Originally Posted by mistacee
HOLYSHIT!!!!
put your old throttle body back on......your new throttle body probaly has a bad sensor for tps and or map. check the gaskets on those sensors. you can change the tps and or map for your old sensors on your old throttle body. but why go through all that work....your old throttle body seemed to work just fine. any check engine codes with your old sensor? find your ecu and tell us what ecu is in the car. read the numbers for us. now check your vtec solenoid....where are those wires running to?
as for the seal?.......there are two diffrnet part numbers for the left and right seals. my guess is that you or the mechanic got the worng one. the mechanic should have known that that seal wouldnt fit. go get a seal for your tranny...so maybe gsr drivers side?
if he says he used a wire harness from an old motor it may not be wired up for v-tech and an ls motor doesnt have v-tech unless u put a v-tech head on it that may be some reasons your v-tech isnt kicking in and i couldent understand much of the rest of the paragraph
Originally Posted by waaBAAH
the person that put in my old motor (LS) when i bought the car said he knew what he was doing with motor swaps. what i didnt know is that he never did a gsr swap into a civic hx. he used my hx harness from my original engine but vtec doesnt work. he told me vtec wasnt working because i had a broken tps sensor. i bought a new throttle body but my car idle jumps irractically from 2500 to 3000 rpms. it stays like this until i shut off the car. the cars idle was perfect before i swapped out the throttle bodys. has this happened to anybody before? i checked my tranny and it was leaking through a seal on the drivers side so i bought a new seal for the mechanic. the mechaic said this seal went in way to easily without the use of a hammer. matter of fact....he just pushed it in. i said "ok, thanks for your help mechanic." the next time i checked the seal....it moved out of place and is riding on the axle.
