AC and Headlamp issues
Old Jun 5, 2006 | 02:39 PM
bleach's Avatar
bleach
Default AC and Headlamp issues
Hey guys long time browser, first time post
1992 Civic Hatch with b16a
1# My driver side headlamp is out, but works with the High beams on, do the settings share the same bulb or a different one?
To replace the bulb do I need to remove the headlight assembly, and to remove that do I need to remove the bumper cover?
2# My AC wont mount to the engine, its been out for some time, do I need to somehow track down a JDM bracket, or is there something else that will work?
3# Where could I possibly find replacements for the back latch bolts for the hatch window? The local Honda Dealer wants 40 dollars for a set of 2 screws!
4# Also is there a place that i could find replacement trim and bolts?, I've gone to a few salvage yards but usually only find 91 and older civics, if I do find one from my generation, the trim is pretty much damaged from the sun already.
Old Jun 5, 2006 | 03:05 PM
i believe the 92-95 civics had a double filament bulb...so when one is out the other still functions. you just need to pop the old bulb out and replace it. be sure not to touch it with ur bare hands because the oils on ur hands can actually heat up and pop them out again... if u look directly behind the headlight, u can see where the wires run, there should be a rubber cover over over them,pry it off gently, and ull see the clips holding the bulb together....
i dont understand ur a/c question... it should all bolt up if it came from that car
repalcements for the bolts,screws,and trim...you can find those at the junk yard...if not look harder online because as far as i know... the junkyard, online classifieds, and the dealer are the only people u can get them.
Old Jun 5, 2006 | 06:40 PM
bleach's Avatar
bleach
thanks for the advice so far.
The swap is a jdm b16a in my 92 hatch. The layout was for the opposite side, and the old ac mount is now on the opposite side for my current engine.
