swap B20b into a 93 civic
Old Jun 4, 2006 | 06:41 PM
JDMBPT's Avatar
JDMBPT
Boosted @ 12psi
Default swap B20b into a 93 civic
I need all info to make this swap. B20b into a 93 hatchback civic.
What parts I need? I have search but I don't find answer
Old Jun 4, 2006 | 07:30 PM
Omniscient's Avatar
Omniscient
warm butter on toast
Complete motor
B series engine mounts
shift linkage
ECU
OBD2 to OBD1 conversion harness
axles
intermediate shaft
engine harness
and basically everything that's on a complete motor, aka distributor fuel rail injectors all that hooplah.
Old Jun 4, 2006 | 07:34 PM
b20hatchy's Avatar
b20hatchy
EM1 Crew member #74
Are you planning on buying a long block or what? It would be the same as any obd1 ls motor. You will use an obd1 ls wiring harness. I had a pr4 ecu in my 93 cx hatch with a b20b. If you are buying a long block from the net you will need a different intake mani wether it be a stock ls mani or aftermarket model. I think thats all. use any b-series trans and motor mounts that will work for your app. Mine b20 had a obd 1 dizzy.
Old Jun 4, 2006 | 09:55 PM
UNIQUEROOTZ's Avatar
UNIQUEROOTZ
Default b20 swap on 93 htchy also
What i used for my swap into my 93 hatch was: b20b engine, B-series mounts, wiring conversion, axles, LS distributor, P75 ecu, GSR tranny, LS intake manifold. Runs great, still minor problems, but easily fixable!!!!!! Just waiting to save up some more cash and go CRV-TEC. Im planning on changing tranny to a b16 tranny, but not sure what exact HEAD would do best for this combo, if u find out, let me know!!!!!!!!!!!!!! keep me up to date on ur swap!!!!!!!!!!!!!!!!!!
Old Jun 4, 2006 | 10:02 PM
Omniscient's Avatar
Omniscient
B16 head. Flows better and is cheaper than a GSR or ITR.
Omniscient's Avatar
Omniscient
Woops. Server took a temporary shit?
Old Jun 5, 2006 | 11:53 AM
b20hatchy's Avatar
b20hatchy
EM1 Crew member #74
Do you plan on building the block?
Old Jun 5, 2006 | 02:12 PM
waaBAAH's Avatar
waaBAAH
tons of debate on this subject.....so search before you believe this.
Old Jun 5, 2006 | 02:49 PM
b20hatchy's Avatar
b20hatchy
EM1 Crew member #74
http://www.team-integra.net/forum/di...g+Common+Topic
This seems to be a pretty good write up about the different b-series cylinder heads.
Old Jun 5, 2006 | 04:29 PM
UNIQUEROOTZ
Default built bottom end!!!!
I am planning on building the bottom end, but since im kinda new to the swaps and all of that, i want to do it the right way. Looking for the 411 on different kind of swaps, but i really like the b20b, so im sticking to it!!!!!!!
