having some problems now that im boostin
Originally Posted by Wreckless96
i don't think that is pumping coolint is because i changed the thermostat and still nothing the. the top hose gets hot but the bottom hose doesn't. and when i did change my thermostat i hardly leaked any coolint onto the ground. maybe my coolint levels are low. and i'm not leaking anything.
if you replaced the thermo...and no coolant leaked out....fill up your car with the right 50 coolant 50 water mixture.
Originally Posted by Jafro
You might have put your thermostat in backwards. I've seen it happen on other cars. I dunno if you can do that w/a Honda & I haven't worked on a Honda in over a year.
Originally Posted by westcoaststyle
I was going to mention this as well...
basically i am just saying is that you are very late to agree with a possible solution when we are already passed that point of the forum
Originally Posted by waaBAAH
maybe this would be good advice if it was one of the first (like when jafro said it up there) but you agree with this eventhough we got a lot farther by talking more about this subject. even if he did put the thermo in backwards he stated that no coolant came out while he loosened up his top radiator hose. this means he doesnt have a lot of coolant...which results in cold air blowing from vents. with the cold air blowing from vents....that is why he thought he had to replace the thermo. bottom line is he has no coolant.
I take for granted the fact that everyone should know their coolant system doesn't work well with air in it.
This problem could be a result of a number of potential issues. I think those that have posted have well covered the obvious issues, but the fact that a potentially inocrrecly installed thermostat could be the culprit in this situation. Thanks again for the well-informed post, captain obvious. :wiggle:
Wow, you do an excecllent job of stating the obvious. I've noticed this about the last few posts you've made. :goodjob:
see how stupid that all sounds? and my posts are informative. tis a lot better then saying...i was going to say that. bottom line....he knows his problem now
nothing was meant towards you jafro.....you state a good possible culprit to the problem but then here comes west coast style a little (a lot i should say) late and he just takes your thoughts. if west coast would have read on he should of known better to think that "thermo backwards" was the problem
hey...that was what i was going to say...darn...you beat me to it.
i might be a noob in post counts towards yours....but then again....you have noob responses to problems. so maybe your post count is from questions that you ask instead of solving others problems?
