Car dont Start and coolent missing
Old May 8, 2006 | 06:26 PM
ewood87's Avatar
ewood87
Eric Wood
i wasnt implying the problems were related, but the starting issue sounds dead on for a bad main relay.
the main relay is a small box (relay) located under the dash near the steering wheel. usually what happens is the solders become weak, and after its warm out they will seperate.. and it will take 5, 10, 30+ minutes to cool back down and work again. im sure threres some DIY threads for re-soldering it somewhere, i know iv had to do it to my integra and civic -- its a fairly common problem on early 90s hondas.
Old May 8, 2006 | 08:43 PM
Wharbone's Avatar
Wharbone
Originally Posted by JDMPONY00
Usually a main relay doesnt cause your car to over heat and coolant loss ,but will cause starting issues. You might have a air lock in your cooling system, tell me this if you run the car for awhile get it good and hot does it act up? Loss coolant, overheat, and not start?
Sounds like it could be main relay to me also.
I think your starting problem and loss of coolant are not related.
Is there any coolant in your oil?
Old May 9, 2006 | 05:16 PM
b18c1_hatch's Avatar
b18c1_hatch
Well it doesnt smell like coolant when im dirving. I havent tryed to start the car after i drove it but when i looked at the radiator it was steaming JUST A LITTLE not too much though but it dident overheat
Old May 9, 2006 | 05:29 PM
JDMPONY00's Avatar
JDMPONY00
overheating can cause coolant to boil away.
