squeak while turning hard left
Old May 9, 2006 | 11:20 AM
asheylarry's Avatar
asheylarry
and if you want to flush your ps fluid, you need to disconnect the line that returns the ps fluid to the resevoir. then you put that line in a bucket and you lift the front of the car. have someone turn the wheel back and forth with the engine running (with the line dissconected of course) and pump all of that old shit into a pan while adding new fluid at the same time until it comes out of the line clear. MAKE SURE YOU KEEP THE RESEVOIR FULL WHILE DOING THIS OR YOU WILL RUIN YOUR PUMP. ALSO USE ONLY GENUINE HONDA POWER STEERING FLUID OR YOU WILL RUIN YOUR PUMP ....or you can go to a shop and they will hook up a machine and flush it
Old Aug 2, 2006 | 05:32 AM
OblivionLord's Avatar
OblivionLord
Is the return line the one directly underneath the resevoir that is connected directly to the PS pump or is it the other line on the side of the resevoir?
