need to replace cv boot
Old May 8, 2006 | 03:48 PM
Kai's Avatar
Kai
Rotorphile.
You don't even need a pickle fork or puller. Wack the side of the LCA where the ball joint bolts down, it will pop out. Pickle forks will often split the boot, make a mess and ruin the ball joint.
Old May 8, 2006 | 05:08 PM
Omniscient's Avatar
Omniscient
warm butter on toast
After the 1st time I do exactly that, but after 10 years of newengland salt, sand, and rust gets in there...it's hell without one.
Old May 8, 2006 | 10:59 PM
Kai's Avatar
Kai
Rotorphile.
True, but that's the exception. I've pulled axles from a Canadian car without one. :dunno:
Originally Posted by darkskyracing
kragen sells a really easy one that is pre split comes with the grease, screws , and clamps. and it only takes about 30 min to do the job
Don't buy "quick boots." They suck, they fall apart within a few hundred miles and only make the problem worse.
