Ctruch or tranmission? Which one i need new?
Old Mar 28, 2006 | 11:24 AM
whookid007's Avatar
whookid007
Default Ctruch or tranmission? Which one i need new?
My car is not moving because i cannot get into gear. My ctruch petal get stuck a little when i push it down. when i push it down and try to put in gear it won't go in and when i put it in reverse doesn't go in but it grinds badly.Before i finally got it in reverse and i let go the ctruch petal a little and it stall out. when i turn it back on i couldn't get it out of reverse and i had to push really hard to get it out and im back to where it started. And i don't know if it is the ctruch or tranmission i need to replace. please help.
Old Mar 28, 2006 | 11:30 AM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
Sounds like the Clutch....take it in and have it looked at.
Old Mar 28, 2006 | 11:36 AM
fathergoat's Avatar
fathergoat
:3
Sounds like the clutch, more spacifically the clutch master/slavey cylinders. Did you check the fluid and look for leaks?
Old Mar 28, 2006 | 11:50 AM
teg92's Avatar
teg92
WHAT OK YEAH!
check your master cynlider, it might be a bad bearing too
Old Mar 28, 2006 | 12:19 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
ctruch? :thinking:
Bleed the slave cylinder and then try it again. Start with the simple stuff...
Old Mar 29, 2006 | 05:32 AM
whookid007's Avatar
whookid007
my dad check to see if their are any leak but their aint. going to get it check today or tomorrow see if i need fluid.
Old Mar 29, 2006 | 05:50 AM
westcoaststyle
A leak would compound the problem, but if you are low on fluid and/or there is a great deal of air in the clutch lines then it will not engage properly because the air is compressing.
Old Mar 29, 2006 | 05:53 AM
whookid007's Avatar
whookid007
alright i will ask about that too
