Low Idle....d16y8
Old Mar 17, 2006 | 10:55 PM
minh47em's Avatar
minh47em
Default Low Idle....d16y8
Hey Guys, I Have A D16y8 Honda Civic, And Everytime I Come To A Stop The Idle Drops Dramatically, I Dont Know What Is Causing It, I Changed The Spark Plugs, And Wires And It Still Drops, It Is Currently On The Freaking Needle Holder At Zero, Help Me!!!!!!!
Old Mar 17, 2006 | 11:21 PM
Wharbone's Avatar
Wharbone
try cleaning out your IACV
Old Mar 18, 2006 | 01:03 AM
InfiniteVTec's Avatar
InfiniteVTec
The Dealer
check your vacuum hoses... that are pinched, also if I'm correct I'm sure that problem is worst occurs at a quick stop after hard acceleration right? I mean as it almost shuts off... RPMS low as 250,300rpms.
Old Mar 18, 2006 | 07:54 AM
Wharbone's Avatar
Wharbone
You guys know that the bottom line on a stock tach (above 0) is 500 right? It is impossible to determine that you rpms are between 0-500, plus I don't think you car would stay running at those levels.
Old Mar 18, 2006 | 08:59 AM
Secondhandloser's Avatar
Secondhandloser
Just how low does it idle?
Old Mar 18, 2006 | 09:29 AM
minh47em's Avatar
minh47em
can you tell me what that is?? im sorry i do not have a clue, and yeah, it like lmost shuts off when i brake a lil harder after accelerating.....
Old Mar 18, 2006 | 12:02 PM
Wharbone's Avatar
Wharbone
Your IACV is attached to your intake manifold. You just un-bolt it, spray the screens with brake cleaner and clean them so no gunk is on them, and re-bolt it.
If you need pictures and help, search this forum.
Old Mar 18, 2006 | 01:35 PM
minh47em's Avatar
minh47em
thanks...im gonna check....
Old Mar 19, 2006 | 08:07 AM
OblivionLord's Avatar
OblivionLord
When my IAVC was dirty, the car would have alot of jerkyness going on everytime I would step on the gas. After I cleaned it, it ran smoothly again. It didn't do a single thing to help the low rpm after a hard brake. I think its mainly just a weak motor because there are no vacume leaks of any kind and it never dips right onto the first line from the 0 but, very close.
Old Mar 19, 2006 | 07:04 PM
RSXt3's Avatar
RSXt3
u may want to check your engine timing (timing belt) my d16y8 started doing this and shortly after timing belt stretched and i trashed a motor
