fuel filter
Old Mar 15, 2006 | 12:00 PM
SIcivic99's Avatar
SIcivic99
SIcivic99
Default fuel filter
I'm looking to replace the fuel filter on my 99 si. I'm needing some opinions on what kind to go with. Is it better just to pick up something at autozone, or should i do something aftermarket, like aem? Any advice would be awesome!....Thanks guys.
Old Mar 15, 2006 | 01:42 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
If you have a stock motor (yes, even with bolt-ons) then you're fine to use an OEM replacement from AutoZone or the like.
Old Mar 15, 2006 | 03:11 PM
b20hatchy's Avatar
b20hatchy
EM1 Crew member #74
yeah just replaced mine and is alot better, its even on the same car as you.
Old Mar 15, 2006 | 05:26 PM
b18allday's Avatar
b18allday
what about a ek hatch itr swap? would you still replace with a oem ek hatch filter? what about the fuel pump? i'm running a 190 walbro, is that going to run lean?
Old Mar 15, 2006 | 05:31 PM
westcoaststyle
What do you have going on with the motor that requires more fuel? Bigger is not always better...
Old Mar 15, 2006 | 06:14 PM
b18allday's Avatar
b18allday
just bolt-ons, fuel rail, pressure regulator/gauge. isnt an itr fuel pump rated at 240 or something? i havent swapped it in yet but just gathing parts before i fire it up. i guess i'll just have to check the gauge when it fires.
Old Mar 15, 2006 | 07:00 PM
westcoaststyle
Well, finding out what the C5 needs to run correctly would behoove you before slapping it in. When it comes to fuel, more isn't better, but too little is very dangerous. With bolt-ons, you won't require more fuel than the stock equipment. You need to be very aware and able to control your fuel when you have a very built N/A motor or FI. You also don't want to starve an upgraded motor so find out what the OEM fuel pressure, injector size (if applicable), fuel line specs (in some cases), and fuel pump LPH specs are.
Old Mar 16, 2006 | 04:17 AM
SIcivic99's Avatar
SIcivic99
SIcivic99
What kind did you go with?
Old Mar 20, 2006 | 03:18 PM
b18allday's Avatar
b18allday
haha nevermind OEM ITR is only rated at 135. i was way off. looks like my current fuel pump will run just fine.
Old Mar 21, 2006 | 02:09 AM
InfiniteVTec's Avatar
InfiniteVTec
The Dealer
Oem
