Newbie Needs Help with 02 sensor
Old Mar 19, 2006 | 06:58 PM
ArsonistsMind's Avatar
ArsonistsMind
ArsonistsMind
Default Newbie Needs Help with 02 sensor
Just got my 93 eg hatch with a b18b1 works fine except my check engine light is on upon closer inspection i seen that my o2 sensor in the down pipe is unplugged. i cant see a connector, so i took a look at all of these threads and i see that i need to do some sort of conversion. Please help i read that i might need to wire it directly to my ecu? if this is true does anyone know of a diagram. Please help!!!!!!
Old Mar 20, 2006 | 12:28 PM
bnuk's Avatar
bnuk
by "threads" do you mean wires? what are the color are the wires coming out of the o2 sensor?
Old Mar 20, 2006 | 12:33 PM
JDM92CIVIC's Avatar
JDM92CIVIC
You can buy a high flo cat with a connector for the plug im pretty sure, im not 100% sure tho..
Old Mar 21, 2006 | 06:51 AM
ArsonistsMind
ArsonistsMind
By threads i mean that i searched through all of the forums
Old Mar 21, 2006 | 06:55 AM
ArsonistsMind
ArsonistsMind
the 02 sensor is there and it is mounted in the down pipe there is just no connector from the wiring harness to plug it into. What i think i need is to wire it directly to the ecu. Does anyone have a pinout?
