removing door panel
Old Mar 15, 2006 | 11:15 AM
menu's Avatar
menu
Default removing door panel
I have a 1994 del sol and i'm needing to repair my right and left side door panel. Would someone help me in removing the door panel and also how to repair or reglue and attached back down the portion of door panel where the vertical portion makes a sculped right angle turn and turns horzonally to for the arm rest?
Old Mar 15, 2006 | 07:27 PM
mishqua's Avatar
mishqua
take off the door handles both door handles, window knob and then get a trim removel tool use around corners. get a bucket of fiberglass. Trial and error or got to the junk yard and get new panels maybe 50 bucks........or ebay
Old Mar 15, 2006 | 08:04 PM
DELSOL98GSR's Avatar
DELSOL98GSR
Hey I just did this today on mine..
For removing the panel!
(I HAVE power windows)
1)Remove screw from top corner of panel.
2) behind the handle there is a lil plastic tab, remove tab, remove screw!
3)carfuly pop off door panel go along the edges, there are clips that hold in in place..
4)when removing panel, u have to slide the handle trim piece through the door panel..
after that fix ur panel. Have fun. Good luck
Old Mar 16, 2006 | 06:59 AM
Secondhandloser's Avatar
Secondhandloser
Remove screws from lock and window panels.
Pull them out.
Remove screws holding door in place, including those around the speakers.
Pull out and up on button of door until the plastic snaps come loose.
Disconnect electronics.
Slide panel up until the top comes unlatched.
