vtec or not
Old Feb 15, 2006 | 02:32 PM
dmelhorn's Avatar
dmelhorn
Default vtec or not
ok I have a 99 honda civic ex. On the block it says it is a D16Y7. Have seen people say that this is non-vtec. THat the D16y8 is the vtec one. But it has the vtec selonoid by the valve cover. SO is it a vtec?
Old Feb 15, 2006 | 02:55 PM
honda guy's Avatar
honda guy
If it has a Vtec solenoid than yeah it is.
Old Feb 15, 2006 | 04:19 PM
Wharbone's Avatar
Wharbone
If it is an EX and has a Y7 in it, the motor isn't the original motor. EX's came with D16Y8's.
If it has the vtec solenoid, it may have a mini-me swap to it.
Old Feb 16, 2006 | 08:51 AM
swaggs21's Avatar
swaggs21
:werd:
You beat me to it
Old Feb 16, 2006 | 09:21 AM
Running925's Avatar
Running925
Your Powder Coater
vtack equipt y0!
Old Feb 16, 2006 | 10:10 AM
dmelhorn's Avatar
dmelhorn
So is having a mini-me swap a bad thing. And could this be causing problems. The problem that I have is this jerking problem. But first I will tell you about what all I have.
I have had my car for a year now. It is a 99 civic ex with a 5 speed. I will be driving it and the check engine light will come on. THe code that it is reading is a idle air control valve error. Now from what I have read the cars idle should raise and lower when you have a problem with the IACV. But it does not, what it does is every time I touch the gas pedal the car kind of jerks and then it will do the same when I let off the gas pedal. But if I push in the clutch it will not jerk when I let off of the gas and push in the gas.
So I took off the IACV and cleaned it really good. It still did the problem. So I broke down and got a new one for 170 and put it on. It still does it. SO I dont think that it could be the IACV.
It also starts to do this problem and throw the code when I make tight corners like u turns.
Could this mini me swap be causing this?
I have heard that the tps could be causing this as well. How much do they cost for a new one. I now that they are rivoted on the throttle body and need to be calibrated. Would it be better to just get a new throttle body?
Sorry for all the dumb questions but this problem has been plaging me since I got the car.
Old Feb 16, 2006 | 10:25 AM
97civicEXVTEC's Avatar
97civicEXVTEC
Usually if you have a bad o2 sensor it will throw a code for the IACV.
Old Feb 16, 2006 | 10:48 AM
Wharbone's Avatar
Wharbone
A mini-me swap isn't a bad thing (as long as it was done correctly). What it means is basically your engine is a frankenstien engine. It is a D16Y7 with either a D16Y8 or D16Z6 vtec head on it (assuming it is in fact a mini-me swap). Have any pictures of it?
I don't see this causing your problems though. Lots of people have done this swap without problems.
Old Feb 16, 2006 | 11:25 AM
bega's Avatar
bega
Im having the exact same problem, the jerking. If im in 2nd gear at 2500-3000 rpm, if I push the gas in, it jerks, and same with letting go of the gas. Feels like the whole engine moves back and forth. It's not the TPS, I change my TB and I still get the same problem.
Old Feb 16, 2006 | 11:39 AM
dmelhorn's Avatar
dmelhorn
I don't have any pictures now but I can get some of it tomorrow.
Could the o2 sensor be causing it to jerk like that.
