Suspension help/ideas !
Old Feb 16, 2006 | 07:22 PM
Chefboiali's Avatar
Chefboiali
scrotal surge
Ok.. My turn. lol 92 Si with 185/60/14's with Si wheel covers, Neuspeed springs and stock shocks. Came with the car. The right back shock feels goes BANG after pot holes and just sounds like something is loose. The top of the arm on the front wheels seem to be mm's away from the top of the wheel well. Are my springs bad too? Should the spring be so short and compressed that it leave so little room? I don't know much about it, but it sounds like there are Yodas in this thread. I like the Si covers. I even took the time to sand them, primer them, hit 'em with metalic them and clear coat them. They look great. I like stock. Would love some Si rims, but for now, I'm ok. Going to put a camber kit on it when I do the swap, but want to know if my springs are done as well.
Old Feb 17, 2006 | 07:24 AM
Jig8's Avatar
Jig8
Yo SIcivic99,
I don't know if i should really be giving advice, because im not a mechanic or anything...but i was in the same situation as you a while ago, so I can share what ive learned, and what i would have done differently. There is a good thread on in the forum in the DIY section that has a step by step on how to replaces your shocks/springs. I might go thru it soon to replace my shocks: check it out:
https://www.honda-acura.net/forums/s...d.php?t=165815
I guess it depends on how comfortable you are doing this kind of stuff yourself...sounds fairly straight forward.
Chefboiali: I'm not sure, but I didn't think springs went bad...I guess they could get over stressed...but I would think your problem lies within the shocks...but again, thats just my thoughts, I could be wrong.
Old Feb 18, 2006 | 09:13 AM
swissarmyca's Avatar
swissarmyca
Originally Posted by SIcivic99
Since we're talking about suspension, I have been looking to drop my car as well. Still I'm new to all of this, so bear with me. I own a 99 civic SI, currently i am running on 15 si wheels. I want to go buy 16's for my car...probably a bronze or so (my car is red). I probably want to go 1.25 to 1.5 drop front and rear. If im gonna lower it i wanna do it right to prevent problems in the future. So im trying to figure out the right kit to get. It's a daily driver, not for autocross or anything. I don't want to buy something that is too much for daily driving. I know i'll need springs, shocks, and i should probably get camber kit. Would someone please let me know what the best route for me to go with would be. Anyone that has an si and has a setup please help if possible. Also i don't know how to do all the work by myself, so i could either get a friend to do it or get someone to do it professionally, which means more money...how much would it cost me roughly for labor if i had to go professionally installed? Any help on this would be great thanks guys!
What you need is a "street" based setup. "Sports" based setup are too low for your purposes and the shocks might also be stiffer making the ride bumpy. I mentioned a few brand names in the above replies. Stick to those and you should be satisfied with your purchase. I do not recommend dropzone or other unknown brands since they have not been tested fully by anyone I know. If you shop around you can piece together a shocks and springs combo for around $350 to $450 for a base setup. Adjustable dampener setups are more expensive.
You do not need a camber kit but if you feel more comfortable with correct camber, then get one. Just remember that alignments are more important than camber. The truth be told, I have omnis on my car dropped 1.5" with no camber kit. 10K Miles later and I am still fine with the wear on V-rated tires.
You can install the kit yourself if you would like to save money. A basic tool kit is all you need. Do a search on this forum and you will find a step by step guide. If not, your local mechanic can do it for $60 to $75 an hour for approx 2 to 4 hours of work. This varies from mechanic to mechanic.
Good Luck with your new project.
Old Feb 18, 2006 | 09:32 AM
swissarmyca
Have a mechanic/expert/guru check out your uppe control arm first. It should be a few inches from the top of the wheel well not millimeters. That may be the cause of the bangs.
Old Feb 18, 2006 | 10:51 PM
meberra's Avatar
meberra
so i i did it myself would i have to cut the bump stops in half??
Old Feb 19, 2006 | 10:29 AM
swissarmyca
If you are buying the Koni RS Kit, they come with bumpstops - no cutting required. If not you may need to buy bump stops that will fit a 12mm shaft. The stock honda bumpstops I believe are for 10mm shafts.
Old Feb 19, 2006 | 10:52 AM
swissarmyca
Update: Koni may still require you to cut their bump stops - check out the instructions in the package.
Old Feb 19, 2006 | 02:24 PM
Chefboiali's Avatar
Chefboiali
scrotal surge
Thanks yo. Before I go spending dough, I better have someone look. I was pretty close to buying new shocks alone, but yeah, I better have someone just take a look. Thanks for the suggestions.
Old Feb 19, 2006 | 11:38 PM
meberra's Avatar
meberra
thanx this has been a really big help
