civic b16 question.
Old Feb 17, 2006 | 09:37 AM
Civic2Scooby's Avatar
Civic2Scooby
Originally Posted by nightscr3en
ok just too out my old motor i did have to go buy new axles i got 99 si axles works just fine got some pics so will post them later tonight or this sat, i have a huge problem i can get the rear and right side to mount but im having problems with the passenger mount anyone ran into this problem before? im using the stock mounts.
which stock mounts
Old Feb 17, 2006 | 09:49 AM
nightscr3en's Avatar
nightscr3en
93 civic dx coupe d16 motor
Old Feb 17, 2006 | 09:55 AM
Civic2Scooby
you cant use those mounts...you need B series mounts
Old Feb 17, 2006 | 10:39 AM
nightscr3en
Ok cool thanks ill pick up the mounts today and give them a shot.
Old Feb 17, 2006 | 10:43 AM
nightscr3en
one other question will the rear mount and the driver and trany botomn mount be ok they seem to mount just fine just the passenger wont mount i went to an auto shop they said about 75$ for the top transmission mount is that a good deal?
Old Feb 17, 2006 | 11:25 AM
mistacee's Avatar
mistacee
Zc powered ED9
will my current mounts and axels work on the motor? and is there anything special that i need to get everything setup?
Isn't this something you should have researched and looked into first before getting into a swap?
It amazes me , with how much info is out there now regarding these old swaps , how much actual homework and research is not done before tackling such a thing. Seems like most ppl buy first then ask questions later.
Old Feb 17, 2006 | 01:34 PM
nightscr3en
well i did do my research but i guess the data that im getting is all wrong but its ok im learning though and just need a but of your guys help and i thank you guys very much sorry if im such a noob at this.
Old Feb 17, 2006 | 02:23 PM
Civic2Scooby
you need B series trans mount, rear mount and trans bracket, Cam side mount...IIRC you can use a couple of your D mounts, but I dont think the ones you are using are those. oh and since it is an automatic, you need a B series auto tranny mount from an automatic integra
Old Feb 26, 2006 | 11:54 PM
nightscr3en
ok just got my engine in ^_^ but the bad news is i had a bad distributor so i took out the distributor from my d16 and put it in the b16 works just fine i can get it to start and everything huge problem is when i step on the gas or reverse the car it goes extremly extremly slow like less then 5 mph for like 10 secs lol but when it gets to around 20 it seems ok i replaced oil transmission fluid spark plugs and everything could it be the d16 distributor?
Old Feb 27, 2006 | 12:09 AM
ReVenGe's Avatar
ReVenGe
i dont plan to be an expert..... but i would say yes
