Quick Question
Old Jan 18, 2006 | 05:16 PM
JDMPONY00's Avatar
JDMPONY00
Default Quick Question
im using a fluidyne radiator, fal fan, spoon thermostat, and fan switch on my b16. well it heats up normally but if i turn my heater on it drops the temp a little is there something wrong or is this natural?
Old Jan 18, 2006 | 06:06 PM
b18allday's Avatar
b18allday
normal
Old Jan 18, 2006 | 06:16 PM
Evil_Omen's Avatar
Evil_Omen
yup it draws the heat away from the engine and accctually the best thing to do when ur car is going to overheat is to roll down the windows and turn the heater up all the way.
Old Jan 18, 2006 | 06:43 PM
JDMPONY00's Avatar
JDMPONY00
alright thats what i thought thanks guys.
Old Jan 19, 2006 | 01:00 AM
Kai's Avatar
Kai
Rotorphile.
The heater core is just a small radiator inside the cabin, keep that in mind.
If you want to warm up faster, start the car with the controls set to full cold. This keeps the heater valve fully closed and keeps the coolant from circulating through the heater core, so when you change over to full "hot" you get the warm air instantly... this will give you warm air two to three minutes faster then leaving it on "hot" from start-up.
Old Jan 19, 2006 | 02:08 AM
EgRocker's Avatar
EgRocker
brain fart
good info . thanks
