changing auto trans fluid tomorrow
Old Dec 16, 2005 | 03:23 AM
mdf1576's Avatar
mdf1576
Default changing auto trans fluid tomorrow
I did a search but Just want to make sure a got it right. I have an 01 civic and basically all I need to do is drain old fliud and put 3 new qts in right?
ANd what do you guys do with old fliud? Can I throw it in with my used oil?
TIA
Old Dec 16, 2005 | 07:40 AM
PDiggityDogg's Avatar
PDiggityDogg
Meanwhile, up in The D
You should really change the filter and use a pump when doing an auto trans flush. Without the pump, youre only going to get like 2/3 of the old fluid out...and really, whats the point then? This is why shops charge nearly $100 for this job...personally, I think its worth it, since it includes the fluid, filter, and labor.
It isnt really oil, so you cannot put it with regular oil...call a few shops and see if they'll take it.
Old Dec 16, 2005 | 08:45 AM
Kai's Avatar
Kai
Rotorphile.
Civics don't have a replaceable transmission fluid filter.
A three quart drain and refill is normal service procedure for younger cars.
A DIY trans flush involves three or four drain&fill cycles, along with some driving time between. It's definately easier with the machine.
Old Dec 16, 2005 | 01:06 PM
PDiggityDogg
no filter???
