engine problem
Old Dec 4, 2005 | 02:45 PM
egzivic's Avatar
egzivic
That is the Air temp sensor. It will throw a check engine code 10. The wires that connect are usually green/wht and red/yellow, I think. Since the harness is chopped who knows? To pull the codes check under the glove box on the right side by the door for a two wire plug. Use a paper clip or wire to jump the two wires together. Then turn the key on and count the blinks of the check engine light. Long bink is first digit short blinks for the second digit. If there are only short blinks the code is only one digit long. Each failure code is separated by a 1-2 second pause.
Old Dec 4, 2005 | 06:19 PM
Hot69Z's Avatar
Hot69Z
Ok thanks, I tried to do that already and It wouldn't pull codes. does it have to be in acc or in run on the key? also I got the number off of the ECU its a P75. Thanks egzivic
Old Dec 5, 2005 | 09:30 AM
egzivic's Avatar
egzivic
P75: 96-00 OBD-2 Integra LS/GS
http://www.c-speedracing.com/faq/06.php here is another how to check your codes with pictures.
Old Dec 5, 2005 | 09:59 AM
bambbrose's Avatar
bambbrose
p75 are also 94-95 obd1 ecu's as well
Old Dec 5, 2005 | 04:57 PM
Hot69Z's Avatar
Hot69Z
Ok then my next question would be how do I tell if its OBD I or II. My other question is what other cars/ motors can i get that plug off of? there is a pick and pull up here at school and im gonna run down there and see if they have any integras, but if they don't what other models can it be found on.
Old Dec 16, 2005 | 12:00 PM
Hot69Z's Avatar
Hot69Z
Ok Im now home from college and got to look at this thing myself. I pulled 2 codes.... I pulled a 50 which as far as i can tell doesn't exist, Though I wonder if its acctually a 41 and im just dumb. I also pulled a 54, How do I check the Crank sensor to tell if its bad? The other thing is I didn't pull up a code 10 for the IAT which I know is completely disconected, any ideas guys?
Old Dec 16, 2005 | 12:17 PM
bambbrose's Avatar
bambbrose
I bet the b18b was obd1 and they don't have crank sensors I think...
but your ecu is for the obd2 b18bs which means it'll look for the crank sensor.
Old Dec 18, 2005 | 07:06 AM
Hot69Z's Avatar
Hot69Z
Ok im gonna crawl under it this morning and see, if its an older block is it possible to hook up a Crank Sensor in order to get rid of that light? And the other code is a 41 which would be the O2 sensor heater so i gotta get under there and see what that all looks like.
Old Dec 19, 2005 | 07:43 AM
Hot69Z's Avatar
Hot69Z
Update,
I found where the IAT is hooked up, the dummies put it on the underside of the CAI down by the filter. Also found the problem with the primary O2 sensor, all the wires are cut and found the harness wires taped and tucked on the fire wall harness. these guys must of been real professionals :P. I also have located 6 other terminated wires and have been hunting them down through different manuals because some of the harness is integra other parts of the harness are civic, this whole wire coding thing is gonna drive me nuts. Now im going to tear down the front of the motor and see what I gotta do for the crank sensor. If anyone knows if it is possible to add a crank sensor if the motor did not origonally come equiped with it please let me know because I have this strange feeling that the motor is an OBD I even though it is hooked up for OBD II. Thanks
Old Dec 19, 2005 | 10:18 AM
bambbrose's Avatar
bambbrose
I'm pretty sure you can get the oil pump or something like that from an obd2 for the crank sensor to work.
but honestly, just spend your damn money on an obd1 conversion harness and a obd1 p75 or a chipped p06.
That way you don't have to worry about these gay ass codes later on.
