high miles on shell
Old Nov 26, 2005 | 06:34 PM
dank24's Avatar
dank24
Default high miles on shell
I am looking at a civic with a b16 swap in it. It has new axles and basicly the whole swap is pretty new. But it has close to 200k on the shell. Just wondering if that is alright to go get? or any problems I may run into.
Old Nov 26, 2005 | 07:52 PM
CaliDELSOL93si's Avatar
CaliDELSOL93si
what year ??? check for rust, check for chassis dammage. If bearings, axles, etc... have all been replaced, go for it.
Old Nov 26, 2005 | 08:48 PM
dank24's Avatar
dank24
um 94 ex. It seems in good condition.
Old Nov 26, 2005 | 09:14 PM
Highmile's Avatar
Highmile
VX Hatch with 431,500!
Any car will have stuff it needs. On my car I sailed right past 200,000. Right past 300,000 and past 400,000 and there was never anything major. It's been the best car I've ever had. It now has 430,000 and I changed the motor recently. I would say go for it just look it over good. I would buy mine agian with 200,000 without thinking about it.
Old Nov 26, 2005 | 09:21 PM
bambbrose's Avatar
bambbrose
just check all bushings, brakes, and wheel bearings thoroughly. also look at the rack and pinon to see if there are any broken dust boots.
Hondas will go forever. What kills them are accidents and rust
Old Nov 26, 2005 | 10:24 PM
Highmile's Avatar
Highmile
He's right, but even if it needs this stuff, I don't consider it major, just stuff to consider. I changed my steering rack for $50 and got the whole thing from tie rod to tie rod. Spend some time with the car and roll up and down every window, flip every switch, turn on and off everything, slide the seats, open the doors, lift the driver door to check the hinges, look for leaking struts, jack up the front end and check the ball joints and stuff, jack up the back end and listen to the bearings (some brake drag will be normal). Then BUY IT!
Old Nov 27, 2005 | 05:28 AM
dank24's Avatar
dank24
sounds good then. Just wanted to make sure before the purchase
Old Nov 27, 2005 | 06:10 AM
acidburn2k2's Avatar
acidburn2k2
before i wrecked my sol, it had 205K miles on it with not a single piece of rust of problem, it's able to handel it
