Boost question
Old Nov 22, 2005 | 11:23 AM
Running925's Avatar
Running925
Your Powder Coater
Originally Posted by 1995Civic
Seems like you have a lot of wasted money into 3 B18's just sitting around, when that money could be put to use for other parts...just my two cents.
bought the last one for 200 bucks.. i woudln't concider it wasting!
car won't be drivin till spring anyways.. so i may as well have 3 forged motors ready for the season! why exactly is this waste?
Old Nov 22, 2005 | 11:58 AM
1995Civic's Avatar
1995Civic
I hate ricers
It's not a waste, as long as you have logical reasoning behind it. There is absolutely nothing wrong it. But if there wasnt a good reason for having 3 motors, whether it's $200 or not, would be a waste. I dont know about you, but i dont have $200 to just go throwing around. Since you have a purpose for your three motors in your garage, and can afford it, more power to you
Old Nov 23, 2005 | 07:35 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
yes.. supposidly stock sleeves can handle 450-500hp .. it's the pistons / rods that will fail. so if you went with forged internals, & made sure the cylinder walls didn't sway via block guard, & used stronger head studs.. u should be able to pull 450-500hp out of a b18 bottom end without sleeving.
i'll make my attempt to prove this when spring rolls around!
Some guy on H-T got over 750 whp out of stock sleeves with forged internals, so it is really all in the tuning.
Throwing around psi numbers is worthless. It all depends on the tuning and the CFM the turbo can flow because we all know that a smaller turbo makes less power at a given psi than a larger one.
Old Nov 23, 2005 | 08:22 PM
raiden571's Avatar
raiden571
turning u inside out
ya, well i farted.
othing wrong with having multiple motors. personally, i wanna build another on the side for all motor. would it be a waste? no, itsa my money and ill spend it how i please. itd only be a waste if i sat around doing nothing, which would be a waste of time.
Old Nov 23, 2005 | 08:34 PM
1995Civic's Avatar
1995Civic
I hate ricers
Originally Posted by raiden571
ya, well i farted.
I already clarified my statement as to HOW it would be a waste. That is perfectly fine to have another motor on the side waiting for build or just in case. I know your Running's boy and all...but you dont have to jump to conclusions and be his voice for everything....
Old Nov 24, 2005 | 06:16 PM
Omniscient's Avatar
Omniscient
warm butter on toast
I want a b18b block...I already got my b16. I wanna put the head on it and get some ls/vtec lovin going on.
Old Nov 25, 2005 | 04:55 AM
Jafro's Avatar
Jafro
I'm made of meat!
A 4g63 holds 21 PSI stock. :fawk: 35+ with ARP's, forged internals and o-rings. A lot cheaper than sleeving a LS motor... but good luck squeezing that cast iron block into a Honda.
Whoever told you a LS motor can hold 20 PSI... don't listen to them anymore.
