wheel rub on 15x6.5 wheels??
Old Nov 2, 2005 | 06:01 AM
jdmeg6hatchy's Avatar
jdmeg6hatchy
i
Default wheel rub on 15x6.5 wheels??
I own a 1992 civic hatch back, i had ROH wheels that rubbed like crazy so I sold them and now have a stock set of 2001 civic wheels with hubcaps, they are 14s with 195 r14 tires on them. they dont rub at all like the ROH wheels did. I was wondering how wide stock 14" civic wheels are? And if I were to buy a set of Rotas in 15x6.5 would they rub?? Thanks
Old Nov 2, 2005 | 06:07 AM
Running925's Avatar
Running925
Your Powder Coater
are u lowerd & it's possible that the wheels are the wrong off set for your car..
Old Nov 2, 2005 | 06:11 AM
HatchVX's Avatar
HatchVX
Driving a Turbo 2L Terror
im running 15x7 and im lowered 1.8 all around and my wheels dont rub
Old Nov 2, 2005 | 06:34 AM
jdmeg6hatchy
i
yeah im lowered. whats the correct offset? how wide are stock honda wheels?????
Old Nov 2, 2005 | 06:37 AM
jdmeg6hatchy
i
heres some pictures of me lowered. we i be able to be that low with 15x6.5's
File Type: jpg
File Type: jpg
File Type: jpg
Old Nov 2, 2005 | 09:15 AM
bambbrose's Avatar
bambbrose
most stock honda 15" wheels are 6 inches wide.
you should be able to go to 15x7 and be slammed pretty bad without rubbing.
15x7.5 and you will start to rub on the outer lip if you have the correct offset, this can be counteracted with the correct camber setting
Old Nov 2, 2005 | 09:21 AM
94civicEX's Avatar
94civicEX
I got worms.
Yea you can count on rubbing with a 7.5" wide tire.
99 Integra GSR
06 TSX
duck squad member #00003
Old Nov 2, 2005 | 09:39 AM
pissdoffB's Avatar
pissdoffB
Little Miss Dee
7.5 is about the most you can fit on a that car, and its a squeeze
Old Nov 2, 2005 | 09:48 AM
HatchVX's Avatar
HatchVX
U should have no prob, u can also roll the fenders also. BTW you have ur sidemarkers wired the wrong way.
Old Nov 2, 2005 | 10:07 AM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
I"ve run everything from 18x7" wheels to 15x6" wheels. Of course wheel/tire rubbing all depends on a few things:
1) wheel width
2) wheel offset
3) tire size
4) how low you are
5) how much negative camber you are running
For a Civic (and most Civic based cars ie: CRX, Integra) a 15x7" with 40-45mm offset works with a 205/50x15" tire. I have 15x7" Enkei RPF1s with 41mm offset, 15x7" Kosei K1s with 45mm offset, both with 205/50x15" Azenis and no rubbing problems. But I'm also running -2.8 negative camber front and -1.8 rear.
With the 15x7" Kosei K1-TS with 38mm offset and the Azenis I was rubbing bad with the above camber (in the rear). With 16x7" Rota C8s with 40mm offset and 205/45x16" Toyo Proxes 4s I would rub lightly on the rears.
With 15x7" Kosei K1s with a 3mm spacer on the front I would rub with 225/45x15" Hoosier A3S03s on the front on the iinner and outer fenders.
Autocross Help Page
