Del Sol d16z6 engine issue question
Old Oct 30, 2005 | 10:37 PM
Fatewolf's Avatar
Fatewolf
Sol Enthusiast
Default Del Sol d16z6 engine issue question
Recently ive been having a problem with my vehicle. First off let me stat that it has just had an oil change and all fluids are new. When the issue occurs there is no check engine light or any other warning lights. What is occuring is that i get an occasional smell of gas. When im driving the engine seems to sound a little loud as in seems to rev louder than it should at certain rpm. Then when i come to a stop at a light, the rpm drops to about 300 rpm and then typically catches back up to approx 700 rpm. No the other day, i left work and when i would stop the engine would stall out unless i was pressing the gas petal to supply more flow to the engine. Tonight, after the stalling issue on thursday, i took the car for a short drive to get the engine temp up, it did the rpm drop and didnt stall, but when i stopped, i checked under the hood and heard a raspy sputtering noise coming from my injector area. I believe it is fuel system issues. I'm just wanting to make sure though. Ive tried injector cleaners and the issue has not gone away, tried new fuel filter with the same results. Fuel pressure at the filter is good. Do you think i need to replace the injectors? Should i get them professionally cleaned? Or is it something else that I may have completely looked over?
Old Oct 31, 2005 | 07:31 AM
Wharbone's Avatar
Wharbone
According to the Haynes manual if the Engine stalls:
1. Idle speed incorrect
2. Fuel filter clogged or water and impurities in the fuel system.
3. Distributor components damp or damaged
4. Faulty emissions components.
5. Faulty spark plug wires
6. Faulty or incorrectly gapped spark plugs.
7. Vacuum leak in the fuel injection system, intake manifold or vacuum hoses.
8. Valve clearances incorrectly set.
Old Oct 31, 2005 | 07:39 AM
Fatewolf's Avatar
Fatewolf
Sol Enthusiast
Ive got the manual also. But like i had said its only stalled once, but if i kept a little extra fuel it ran fine.
1: Idle speed and IAC are good and tested
2: Brand new feul filter, issue happened before and after, i use ethanol whichi removes moisture from the system
3: distributer checked out fine
4: map sensor is fine and no noticible exhaust leaks.
5: Brand new spark plug wires within 3000 miles, issue was happening before and after
6:Brand new spark plugs, within 3000 miles, issue happened before and after
7: Havent found a vacuum leak yet
8: Valve adjustment done approx 1000 miles ago when new cylinder head was put on, all gaping correct. Did have issue with this though, for some reason when the new rocker arm assembly was put on, if you did a cold adjustment, the gaps got worse when it heated up, if you did a warm adjustment at idle operating tempature, it had no issues.
