projector lights
Originally Posted by VTEC
Halogen light bulbs are also "gas filled capsules". =)
The main difference is that in a standard bulb, the light is emitted from a tungsten filament. In a metal halide aka HID bulbs the light is emitted from an arc.
It's illegal to install HIDs in your Civic (if you care about legality). Most cheaper kits are crap because they use the stock headlights (designed precisely for a filament bulb) to disperse the light from a xenon arc. Lots of throwaway light and glare. I'm sure there are good kits out there.
y is it illegal to have HIDs in my civic?
Throwaway light/glare is dangerous for oncoming drivers.
Anyways, I didn't really get the reason behind you wanting to get new headlights.
Is it for cosmetic purposes? Do you want to see better?
My recommendation to you is to keep the stock headlights and use a street legal high output bulb. GE has "Nighthawk" (formerly HiVision). Osram Sylvania and Philips also have their own versions of "30%" bulbs. They are clear capsules but they get extra lumens from a different gas mixture (the package usually touts a higher percentage of xenon in the mixture) and a tighter filament wind. However, bulb life is sacrificed. Or if you want whiter but legal light, stick to FMVSS#108-compliant bulbs by GE (Super Blue), Philips (BluVision), Osram Sylvania (Cool Blue or Silverstar), and Wagner (LazerBlue). All are available at WalMart and auto parts stores. Keep in mind you won't see any mindblowing improvements on par with HID output.
I like the style of the projectors. I'm disappointed though with the light dispersement is less than stock. Does anyone think the projectors with the high output bulbs would do me justice. I would like something brighter with some style but done want to get into HIDs. Should I just add fogs with the projectors?
are projector headlights any good or should i just keep my stock? and how bout the halo headlights? is it true that 3rd party lights suck anyways? sigh...choices
Does anyone know what if Xenon or HIDs are hotter? If HID's are way cooler as in temperature... I'd just order new Halos and just run HIDs in them.
