View Poll Results: so whats better for yall,
springs
5
45.45%
coil overs
6
54.55%
Voters: 11. You may not vote on this poll
lowering ??
Old Sep 9, 2002 | 08:04 PM
SYKOTIC_CIVIC's Avatar
SYKOTIC_CIVIC
Default lowering ??
ok everyone drop a line whats better Springs , Coilovers , or whats on ur mids pple drop the linez up in here latezzzzz,
Old Sep 9, 2002 | 08:16 PM
pinoydon2003's Avatar
pinoydon2003
wow look 100% for springs.. looks like it wins unanimously.. heh jk
when u say coilovers, i'm assuming u mean the "coilovers" like skunk2 and not the true coilovers like Apex..
i recommend u get like a 1.8" drop with eibach or H&R sport or something like that.. it'll look clean, you won't have to worry about scratching that much, and you won't need aftermarket shocks
Old Sep 9, 2002 | 08:45 PM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
I cant see shit. Type in a normal color
Nelson's Avatar
Nelson
Administrator
Depends on what your lifestyle is... daily driven, I'd say some springs with some quality struts... for show, I'd say coil-overs, dro it as low as you can, then back up, so you can drive the car back from the show.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Sep 10, 2002 | 03:00 AM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
It depends on what you want to do. Coilovers require balancing the car and requires some know-how and patience to do.
Springs once you lower it you get an alignment and you are done.
Autocross Help Page
Old Sep 10, 2002 | 06:58 AM
dantastic's Avatar
dantastic
cx power!
i dont know anyone (personally) that had their corner wieghts set on scales, etc. everyone i know that has coilovers has just set the ride height the way they want it including myself. i dont find it necessary. will it reallly make a huge difference in handling ability?
Old Sep 10, 2002 | 07:05 AM
qtiger's Avatar
qtiger
Depends on how you set them, but yes. If you aren't going to be tuning and adjusting your suspension (the true reason for coilovers), most people should smiply get a decent set of springs which will put them at the height they want.
How many times have you changed your height?
Old Sep 10, 2002 | 07:15 AM
CivicSiRacer
I didn't corner weight my car either, but I have my front left/rights and the rear left/rights within 1mm of each other (with my weight in the driver's seat and 1/8 tank of gas). Handling is so much better than with Eibach lowering springs - also because they are a stiffer spring rate.
Autocross Help Page
Old Sep 10, 2002 | 08:39 AM
Nelson's Avatar
Nelson
Administrator
Originally posted by qtiger
:chuckles: :werd:
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Sep 10, 2002 | 08:47 AM
dlh1999's Avatar
dlh1999
Runs with scissors.
This post has actually helped me out, too. I was pretty set on getting coilovers (well, coilover sleeves) so I could put my car at the height I wanted it at. But after reading this, I'm thinking springs are the way to go. Now for another question...what kind of drop would look best/handle best? I want to be low, but not too low...it's a daily driver.
